My slip shaft solution was in conjunction with a
widened front A-arm setup, a total of 4-5 " now
if you have seen a Track/Kick front housing you
know it's not very big, and the additional 2 or so
inches, along with the removed CV cup, you now
have gained a longer CV shaft, about 4" per side,
and about the same as you will gain with a centered
front diff, with out all the hacking and welding.
This would be a bolt in and removeable setup, so
it could be moved to another vehicle, or heaven
forbid, you descide to change back to stock configuration
Zukizzy and I have talked about front drivelines (halfshafts) and I think we can come up with a
solution that will be Zuk based soon
