solid axels and leafs in a 95 tracker
  • 1425 Views
Offline TrAkLsI
  • 61
« on: June 10, 2006, 12:57:16 AM »
What is easer to put 85 4runner, samaurai or cj axels under a tracker 2dr.  I'm just throwing ideas for the cheapest way to put solid axels under a tracker.  thanks guys
Offline DWiddowmaker
  • 59
Re: solid axels and leafs in a 95 tracker
« Reply #1 on: June 10, 2006, 08:35:32 AM »
Depends on your skill level... Toss the samurai idea, they are weak and narrow. Most common swap would be the yota axles, and these would require the least amount of fabrication and money, however if the jeep has like dana 30/44 or something like that, you can get them cheap, and can narrow them, that works out too. Hope this helps.  ;D
Offline chet
  • 556
  • Zuki time!
« Reply #2 on: June 13, 2006, 08:52:57 AM »
toy axles would be easiest and cheapest I think. Although everyone forgets about gearing. Toys you can get 5.29's but with larger tires thats not enough. You can get 5.71 but they are weak.
Offline red_baron
  • 108
  • little red vit
    • surrey zuki society
« Reply #3 on: June 13, 2006, 01:41:35 PM »
i run toyota mini truck axles and leaves under my 4door.
 to overcome the gearing issue i have a twin t case set up, though swapping the track t case for a sammy box will work fine with tyres 33" and over.
http://s5.photobucket.com/albums/y185/MUDDYJLX/toyota%20axle%20swap/
Offline SnoFalls
  • 1358
« Reply #4 on: June 14, 2006, 08:42:19 AM »
yup that's why I going with D44's ... so I can get 5.89's
