Will a 1.0 liter swift engine bolt in?
  • 16 Replies
  • 2888 Views
Re: Will a 1.0 liter swift engine bolt in?
« Reply #15 on: May 14, 2006, 08:30:47 AM »
I was wondering if I could get this engine(with the proper gearing) to work effectively in a tracker.
I think gearing would be a big problem, you would have to go a fair bit lower to compensate for the additional weight of the Tracker. The Tracker has a combined gearbox/Tcase, the Sammy has a divorced tcase, a Sammy gearbox and tcase might work OK as the Sammy has a lower ratio high in the tcase.
« Reply #16 on: May 14, 2006, 08:39:37 AM »
No, you will need an adapter, and it might
not be tha same as a 1.3L engine bell housing,
but these 2 engines share the same bore and
stroke, I'm thinking they are the same bellhousing
