tracker rear end
  • 22 Replies
  • 3440 Views
0 Members and 18 Guests are viewing this topic.
Re: tracker rear end
« Reply #15 on: March 15, 2008, 10:22:16 AM »
I would just call Hawk Suzuki Parts and tell them the bolts you need.  They usually will ship it out that day.  They have shipped more then a few bolts to me based on "that one bolt" being the description.  :)
Offline Cuthulu
  • 384
« Reply #16 on: March 15, 2008, 10:30:18 PM »
And he is really patient, especially when these kinds of parts calls rarely run over 15$.  I know from experience.
Offline Armour
  • 360
« Reply #17 on: March 16, 2008, 05:44:46 AM »
I don't think you guys read the post correctly. On the first one he states he needs to tap the holes! I don't think Hawks bolt will help him do that!LOL!
89 Sidekick. 33's.  Lincoln Locker,4.24 T Case, 5.13 gears. Warn M8000 winch.
96 Tracker. 39.5's Locked 44's front and rear, 6.5 t case, 4.10 gears.
Offline mic
« Reply #18 on: March 16, 2008, 06:01:53 AM »
As for the proper thread size I'm not sure. Swapping the rear end is pretty straight forward and not very difficult. The real pain is the trailing arm bushings get seized to the bolts. Also make sure your new rear end gear ratio matches the front. All in all it would be easier to tap the four holes than change the rear.
91 Tracker Calmini 3+3 31x10.5 swamper ssr
88 samuri 3" body 2"susp. 31x12.5 boggers sold
03 super duty daily work truck $$$$gas
« Reply #19 on: March 16, 2008, 12:02:54 PM »
The bolts are shouldered so you should be able to measure the shoulder on one of the broken bolts. They will be either M8 x 1.25 or maybe M10 x 1.5, I would just buy the bolts from Hawk and then measure them.
Offline tracker8v4x4
  • 128
    • cardomain
« Reply #20 on: March 16, 2008, 06:27:34 PM »
thats prolly what i will do probably just order that and find out the tread size and tap them and the reason i am swaping rear ends is that i have one that i welded
« Reply #21 on: March 17, 2008, 12:51:01 AM »
Yep, missed that he needed to re-do the threads.  I thought he just sheared the bolts off.  :P
Offline 95tracker
  • 104
  • It'll fit Perfect!!!
« Reply #22 on: March 21, 2008, 10:27:05 AM »
They make a special fluid for Limited slip diffs the increase the friction of the clutches, but it is only for LSD's or a posi. It wont do anything for an open differential.
I think you are referring to the "limited slip additive" that I was referencing earlier......it is not to increase friction in the clutch plates (I thought the same thing for awhile), it is to make it so they don't chatter.
Ya i got to thinking about that a day or so after i posted it and i knew it was wrong and forgot to fix it thanks for the correction.
