has anyone tried strengthening the front ifs with xl7 axles? it should fit right in without or with minor modification. the xl7 axles are designed for a greater torque and hp. it should be a lot stronger than that of stock.
Most all the pieces are the same. The improvements would be the Steel center housing and steel third member. Both of which will bolt in. The following article from the ZUKIWORLD archives shows us using a XL7 steel center section and an GV manual third member. The XL7 third member will work as well and actually has a better "snout mount" but you will need the mounting brackets as well to bolt it to the crossmember.http://www.zukiworld.com/month_090103/feature_sidekickdrivetrainimprovements.htmGood Luck, Eric
