Grille clips? Small parts not available through GM? (discontinued dealer item)
  • 14 Replies
  • 5115 Views
Offline djlantis57
  • 871
  • Take your chrome home
I broke the two upper grille clips on the 1990 Tracker grille when I was removing it a month ago.  Knew I would have to replace them when I start putting it back together right about now.  GM discontinued this item, no longer available.  Where can I find small, "insignificant" little parts like this that are still in good condition? I could easily bolt the grille or safety-wire it, but I want it easily removable like it used to be.   I haven't tried Hawk yet, but any other ideas?
xkmail
I got a whole grill on ebay for $70 brand new.
I went over to the junkyard and found the little screws and clips there, paid $1
I have a 1990 track also.
However i broke the geo tracker emblem so maybe I will put something else there.
Also my headlight mounts are goofed, oh well I don't drive much at night anyways
If you cant find what you need at a local junk yard, give Hawk a call ad 1-888-SAMURAI
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
i have found them at auto paint stores  i work in auto parts as a counter man we get asked a lot and thats where we send them
Offline djlantis57
  • 871
My geo emblem was missing already when i got the tracker...better airflow without it anyways so I'm leaving it off.  (all emblems and side mouldings were stripped before I bought it)  The grille is still held in by the 5 screws, I put it back on with new stainless steel screws and larger stainless washers.  IUt's not giong anywhere, the little black clips just secure the top from rattling, that's all.  Kragen, NAPA, don't have them.  Haven't tried junkyards yet, but I don't see how I could remove them without breaking them: they look like a one-time installation kind of thing.
Where do you mean paint stores?  Any suggestions helpful.  Thanks for the replies so far.
Offline ToyYoda
  • 226
LOWES. They have the "push in" clips in sevearl sizes. Cheap too!
Offline djlantis57
  • 871
Hey everyone I found something in my garage, if it works, I will post some pictures on what I did here
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
Just pop up the center portion a bit with a small screwdriver.  This pulls up a plunger that keeps the out parts spread apart.  Then wiggle it out.
XL-7 front coils
1.5" rear coil spacers
Offline djlantis57
  • 871
Here's what worked:  my dad removed a few "flush-can" ceiling lights from a house, and while stripping out the copper for recycling, I found these clips:
so I bent the tab flat, and screwed it to the bottom of my front clip crossbar, with a black screw, and it doesn't show, holds the grille up close to the body, and allows the grille to slide in and out freely
I used bailing wire.
01 Tracker - OME Springs, 2" MK1 Body Lift, Warn 6K Winch, 18x9 Wheels, Rear Roll Cage and more.  95 Tracker with all Calmini bolt ons.  96 X-90 with mini lift and Super Swampers, this one has A/C and is an auto, nice.
Offline Uncivilized
  • 1469
    • Car Domain
haha - my grill is held on with one screw and plastic ty-raps ;)
Offline djlantis57
  • 871
I didnt want baling wire or zip ties since I wanted it easily removable, but hey that works too!!! Whatever holds it together huh?
I looked through those HELP! wall displays at Kragen and NAPA to no luck, never checked autozome though
There are mix and match of about 5 different types of clips/fasteners that hold the grille in...depending on what year you have.
There are the 2 piece type that have the plastic "pin" in the middle of them.  To remove them, you push the center pin in about 1/8", then that will release the fastener where you can get something under the outer edge of the head and pull it out.  To reinstall it, you pull the center pin out, put it back in the outer piece, until there is about 1/8" of the pin sticking out, push the fastener in the hole, then push the center pin in flush with the outer piece.
There are the 1 piece type that just push in.  Usually, you can get something under the head and pull them out.  But sometimes they will pull in two, or strip the outer "hairs" off and they won't hold when you reinstall them.  To reinstall, you just push them in the hole.
There are a couple of variations of the type that djlantis57 was trying to find.  They are plastic and the one type will usually break every time the grille is removed.  The other type, you can usually take a thin flat blade screwdriver and gently push down on the center "hump", so as not to break the clip or the grille, and gently pull on the grille and it will pop out (the clip stays in the grille surround).
Then there are screws.  Pretty self explanitory on removal and installation.
As some of you have noted, some of these can be found at auto parts stores or other places.  And some are next to impossible to find.
When I was looking for the 1 piece type that just push in and pull out for my Ranger, I could actually buy them cheaper at the dealer than at the auto parts store.
BTW, djlantis57, excellent find on the metal clips.  Those should last forever and look like the grille should be much easier to remove than with the plastic clips.
« Last Edit: July 14, 2009, 09:00:36 AM by Skyhiranger »
Offline djlantis57
  • 871
Yup it is!  I removed it three times since then and I'm 3 for 3 not breaking anything.  I broke the plastic clips the first time cause I didn't know what I was doing.  And the "plastic weld" wasn't gonna hold them together, so I had to improvise.  I still had 5 screws holding the grille in anyways
