double up tcase in sammy
  • 11 Replies
  • 2156 Views
Offline bandit86
  • 1641
  • elv8rguy
« on: August 26, 2004, 12:35:49 PM »
what's involved?
Offline cj
  • 1276
  • I drive a really big ATV
Re: double up tcase in sammy
« Reply #1 on: August 26, 2004, 11:16:28 PM »
Anorther tcase  ;D
Offline bandit86
  • 1641
  • elv8rguy
« Reply #2 on: August 27, 2004, 03:16:01 AM »
no kidding... Anybody make necessary brackets and shafts?
Offline DoctorD
  • 68
  • No such thing as too many toys!
« Reply #3 on: August 27, 2004, 03:33:00 AM »
OTT makes a set up to bolt the kick case to the sammy case.  you can find it here:
http://www.ottindustries.com/kicker3.htm
It's not a kit...but a $600, it's not bad.
D
In search of new toy
Offline nc_zuk
  • 406
  • Back in North Carolina
    • www.samurai4x.com
« Reply #4 on: August 27, 2004, 03:49:34 AM »
noone makes a kit to put 2 sammi t-cases in a sammi. It has been done though but it would be a full on custom fab job. It is much easier to put 2 yota cases behind a 1.6 zuk engine. Check out http://www.rock4xfabrication.com and look for RingR ;D
www.Zuwharrie.com[/url]
Offline szabotage
  • 114
  • snaggletooth
« Reply #5 on: August 27, 2004, 10:50:17 AM »
I homefabbed my dual zuk t'case setup and maybe only spent 100 bucks on steel and the tig welding.  It works well but it's not for the light hearted.  Alot of trial and error was involed, thus it took me almost all winter to do
parts you'll need:
1) trac kick motor or lower block or a 1.3 to kick tranny adapter
2)trac kick tranny/t'case
3)front or rear kick driveshaft
4) lots of metal for fabbing mounts
5)aluminum plate
special tools you'll need:
1)mig welder
2)tig welder
3)chop saw
4)cherry picker(couldn't hurt!)
5)angle finder
6) did I miss anything else?
what you need to do:
1)extend your wheelbase at least 9 inches in the rear
2)chop off the front output off the kick t'case after removing the chain drive
3)tig weld the case shut so no oil leaks out
4)narrow the kick driveshaft as short as possible (intermediate shaft)
5)build the mounts for your new drivetrain (get creative)
6)extend the sammi front driveshaft
7) cut out you tranny tunnel to make room for the new gearshifters
this is a basic coverage of what your up against, there are more factors to aknowledge  when doing this setup, some even to consider if you decide spend the money on the OTT kicker instead, so all I can say is think and plan it through and if you got any more questions you can send me a PM ;)
mike
Offline 1bigtracker
  • 3409
« Reply #6 on: August 30, 2004, 05:50:24 AM »
isn't a cherry picker used for trees???
stu
Offline trackermad
  • 150
« Reply #7 on: August 30, 2004, 06:43:56 AM »
I thought they were used for cherrys.... ;D
"First of all: what is work? Work is of two kinds: first, altering the position of matter at or near the earth's surface relatively to other such matter; second, telling other people to do so."  ~Bertrand Russell
Offline szabotage
  • 114
  • snaggletooth
« Reply #8 on: August 30, 2004, 11:25:42 AM »
*edit* engine crane is the term I was looking for,
not sure why we call it a cherry picker, must be a Canadian thing  :-/
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #9 on: August 31, 2004, 02:00:47 PM »
That all I've heard them called (cherry picker) here in Michigan.
96 Tracker
32 MTR's Warn 8000i
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #10 on: August 31, 2004, 02:02:49 PM »
OTT has kits to put a Sami T-case to a Trackick T-case.
96 Tracker
32 MTR's Warn 8000i
Offline explosivo
  • 3157
« Reply #11 on: August 31, 2004, 02:16:04 PM »
Me too.  :-X
omghi2.us[/url]
