Double T-cases for a Track/Kick..Another Pic worth 1000 Words!
  • 19 Replies
  • 4232 Views
Offline aftermarket4x4
  • 145
  • ZUKIWORLD
« on: November 14, 2005, 06:05:46 PM »
Sean (Puppy-dog approved!) DeVinney
Offline suzukiboyoz
  • 194
  • Friends don't let friends ride a Yamaha
    • http://community.webshots.com/
Re: Double T-cases for a Track/Kick..Another Pic worth 1000 Words!
« Reply #1 on: November 14, 2005, 07:53:11 PM »
For someone that does not know what he is looking at (me) what is the benifit of the design?
Calmini 3" Suspension Lift, Calmini Skid Plates, Calmini Rockhoppers, 30" Mud TYres, ARB Bullbar, Rear ARB Locker, Custom Sill Sliders, Rear Bumper and a lot more.
Offline Guardrail
  • 101
« Reply #2 on: November 14, 2005, 08:22:48 PM »
Lower gears and a larger selection of lower gears.  (low in t-case A)x(low in t-case B)=double the crawl ratio.  And if you put a 4.24 gearset in one of them,  you end up with even more available ratios.  (1.81 stock, 4.24 low and 1.81x4.24[7.67] ultra low)
Can he say that here
Later,
Guardrail
Offline Guardrail
  • 101
« Reply #3 on: November 14, 2005, 08:24:14 PM »
Where can I get one for a GV?
And, what is the second case and how did you mount it?
Later,
Guardrail
mudfkr
« Reply #4 on: November 14, 2005, 08:25:31 PM »
It helps the driver concentrate on just steering the rig as the passenger in the back can change gears for him with the stick mounted further back there.  ;D
Also duel case's equal lower gearing and more choices for ratios thus making the rig even safer by going slower , less impact if you hit some thing  much  much safer  ;)
Offline red_baron
  • 108
  • little red vit
    • surrey zuki society
« Reply #5 on: November 15, 2005, 12:56:55 AM »
is that the kicker 2.?
i did mine by mounting a sammy t case to the back of a track t case.
works well.
  • 145
  • ZUKIWORLD
« Reply #6 on: November 15, 2005, 04:47:58 AM »
works well.
Nope, it's not a Kicker 2.....It's a "Kick Box" that I designed and built.
Sean
The Dual Kick T-cases are mounted together using a completely custom adapter plate and specially machined output shaft. Pass side front output is cut off of the first case so as not to interfere with the output of the second case. This setup only adds 9 inches to the total length.
As it says above, I am calling this the "KICK BOX"
Sean DeVinney
Offline red_baron
  • 108
  • little red vit
« Reply #7 on: November 15, 2005, 05:07:38 AM »
very nice.
 ;D ;D ;D ;D ;D ;D
Offline 1bigtracker
  • 3409
« Reply #8 on: November 15, 2005, 05:49:01 AM »
sweet!  so how much $$$ sean?
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #9 on: November 15, 2005, 09:37:38 AM »
When are you installing that?
 Do you plan to make a new gear level as mudfkr says your co driver will be in the back seat unless you get out se the gear then drive on ?
be interested int he pics
Markyb (UK)
UK Vitara JLX SE
Offline takai
  • 907
« Reply #10 on: November 15, 2005, 10:17:20 AM »
And that's the most important thing isn't it.  ;D
Looks really nice.
'Cause, I am to misbehave.
Offline 1bigtracker
  • 3409
« Reply #11 on: November 15, 2005, 12:54:50 PM »
just thought of a plus on this over a kicker3,  you don't need an offset rear to use it with out vibes(yea yea, CV shafts bla bla bla)
Stu
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #12 on: November 15, 2005, 05:37:26 PM »
Wow, now this is interesting....We need more details than a pic!!! A 1000 words will do nicely! ::)
 ;DMike
  • 145
  • ZUKIWORLD
« Reply #13 on: November 15, 2005, 06:51:37 PM »
Are you sitting down?..... because you'd choke if I told you. Right now it costs way to much to economically sell it, but if I can find a way to make it cost effective I would like to build more of these although mass production, like with the Toy setups, is not currently a possibility. Please keep in mind that I am not posting these pic's as a "for sale" ad, but rather to get other peoples creative juices flowing....... 8)
I'll be installing it after I finish up a few customers rigs. I still have a 2.0 swap to do, a 1.9TDI swap, and another Tracker SAS to do in the next few weeks. The second t-case shifter is only moved back 9 inches from the original location so it is still between the seats. This setup is almost the same length as the Toyota dual T-case setup and would easily work in a Track/Kick or LWB Zuk just like a few guys I have seen with Yota stuff in them.
This will add a whole new set of options for guys that want more gear selection.....about 8-1 when used with the lower gearsets in the market.
 ;DMike
No detailed pic's for now, but what questions do you have about the Kick Box?
Sean
« Last Edit: November 25, 2005, 05:07:31 AM by aftermarket4x4 »
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
« Reply #14 on: November 15, 2005, 07:57:36 PM »
Well you answered a few of my questions. Couple still remain. ;D Really interested in this. Keep us updated on if you can streamline the proccess. Definately drop us a price when your ready.
Mike
