gear lash
  • 1570 Views
gear lash
« on: December 23, 2005, 04:46:51 PM »
 ??? Hey guys, in the process of installing my arb, and as per practice, before i removed the old diff I measured the gear lash between ring and pinion. I got readings of .003 and .005  90 + 180 degrees apart. I checked this several times as it seemed a tad tight to me. This is the used gear set I picked up for my auto, and it has about 130k on it. All the teeth look good, and it ran quiet. That just seems tight to me, but what do I know, my 1st zook. Any input on this would be greatly appreciated!  Thanks
Re: gear lash
« Reply #1 on: December 24, 2005, 12:44:54 AM »
Spec is .008 so yours was not way too
tight, but a little more wouldn't hurt
Re: gear lash
« Reply #2 on: December 24, 2005, 03:48:10 AM »
Thanks Wild, I may add a bit to the new set up.  BTW, how many posts does it take to move up from newbie status anyway?
Re: gear lash
« Reply #3 on: December 24, 2005, 12:19:58 PM »
I dunno, about 200 or so
Re: gear lash
« Reply #4 on: December 25, 2005, 07:23:16 AM »
 ;D  That should't  be too long, as I keep f%#$king up and having to get help! Thanks again , I really appreciate this forum, and all the expert advise. Mike
