dome light fix?
  • 22 Replies
  • 6222 Views
Offline tdrrally
  • 42
Re: dome light fix?
« Reply #15 on: September 11, 2012, 05:00:57 PM »
thank you for all the input
i found away to make it work
there is silver box above the gas pedal
there are 2 white wires one with power and one with out
if you jump the 2 together the dome and map lights work as designed .
it used to tune the dome light off when you put it in drive and now it takes a couple minutes
so it looks like the control box is bad but the dome lights work
Offline tdrrally
  • 42
Re: dome light fix?
« Reply #16 on: September 12, 2012, 07:05:10 AM »
update #2
after driving to work this morning every thing is working again
the day time lights the dome and map lights every thing!
Offline augeter
  • 9
Re: dome light fix?
« Reply #17 on: September 17, 2012, 12:14:16 PM »
So, what was it that fixed the problem?
"It seems common sense just isn't very common anymore"- Eustace 2012
Re: dome light fix?
« Reply #18 on: September 19, 2012, 02:00:00 PM »
It sounds like that silver box isn't allowing power through like it is supposed to.  Without a wiring diagram or repair manual I have no idea what it could be though.  Maybe someone else will chime in.
Offline Derek
  • 63
Re: dome light fix?
« Reply #19 on: September 23, 2012, 07:52:45 AM »
On the interior light subject I put a LED kit from NAPA in my 93 sidekick. It was from street glow but I forget the part #. just snaps into the light socked with a little bending of the tabs and it is a square sheet of LEDs. Now I can leave it on accidentally and not draw the batts down as much. And it is a cool whiter light then yellow. better kevlins.
  • 4313
  • 167
Re: dome light fix?
« Reply #20 on: September 23, 2012, 11:27:59 AM »
I've used a similar LED "replacement bulb" in the dome light on my Swift and the reading lighst of the GV, but after a while I took them back out - they were so bright they hurt my eyes.
Offline Derek
  • 63
Re: dome light fix?
« Reply #21 on: September 24, 2012, 07:16:38 AM »
Well your not suppose to drive with them on.
  • 4313
  • 167
Re: dome light fix?
« Reply #22 on: September 24, 2012, 07:22:28 AM »
Who said anything about driving?
Taking your comment at face value though - GVs are fitted with map/reading lights - using LEDs in the map/reading lights renders them vitually useless, either for reading with the vehicle stationary, or driving with a co-driver or navigator attempting to use the passenger side light to read a map or route instructions
