size tires for stock tracker WITH body trimming
  • 1053 Views
Offline gc3
  • 12
« on: June 12, 2009, 10:51:48 PM »
Hey guys,
I know 235/75/15s are the norm for stock trackers, but what about if you were totally okay with cutting a lot of the body?
Im still on stock wheels, so im assuming anything wider than that would end up with rubbing frame on full steering angles, but if i get a bigger backspaced wheel, (how much more i should get... umm.. help?)
but how big a tire can i run without rub issues as long as im okay with cutting body panels?
Offline Bryce132
  • 117
Re: size tires for stock tracker WITH body trimming
« Reply #1 on: June 13, 2009, 07:30:28 AM »
Depends on where you live I suppose. You can't trim too much around here in the snowy northeastern as you need to have the wheel's covered, and require an inner fender guard.
I have seen 31's on a stock 94 Tracker, the body trimming actually didn't look to bad, would go ALOT of places because of the LOW COG. However it looked and performed much better with just a 2'' lift (jeff's)
Will try and find a few pictures.
Bryce
« Reply #2 on: June 13, 2009, 08:16:53 AM »
Could you possibly use something similar to bed liner spray to cover the metal if you have to cut the plastic liner to keep water out?
01 Tracker - OME Springs, 2" MK1 Body Lift, Warn 6K Winch, 18x9 Wheels, Rear Roll Cage and more.  95 Tracker with all Calmini bolt ons.  96 X-90 with mini lift and Super Swampers, this one has A/C and is an auto, nice.
Offline gc3
  • 12
« Reply #3 on: June 13, 2009, 08:23:29 PM »
im in michigan, and since we have no inspection, i should be okay unless its totally out there.
i can easily fabricate some fenders if needed, and can weld in patch panels if i need to as well.
also, since im not gonna go outrageous places, more of a look rather than total offroadiness, so wide is better for me.
i am eyeing some 15x10" wheels with a 3.75" backspace... will that be a good backspacing for a stock height tracker? and how wide of a tire (even at expense of a shorter tire up to a point) can i get on there without rubbing frame?
always the possibilty of rally crossing if it seems stable enough too.
