Heater Fan Problems
  • 1960 Views
Offline Loyal
  • 47
Heater Fan Problems
« on: August 25, 2004, 06:37:24 AM »
I just turned on the fan this morning and noticed that it will only work on the Top setting.
Is this a common problem?
Would this be the fan or a linkage of some sort?
Is is difficult to fix?
Loyal
1997 4 Door Kick
Offline trackermad
  • 150
Re: Heater Fan Problems
« Reply #1 on: August 25, 2004, 07:33:32 AM »
Its a easy fix...  Most likely your resistors burnt up. Just remove your glove bos and look in behind it there are some wires that hook into the air box just in front of the fan.  One screw and you can pull the resistors out.  You can get them from a dealer for about 20 bucks or sorce one from a junker.
"First of all: what is work? Work is of two kinds: first, altering the position of matter at or near the earth's surface relatively to other such matter; second, telling other people to do so."  ~Bertrand Russell
Offline jerryp58
  • 449
« Reply #2 on: August 25, 2004, 09:28:32 AM »
Bad switch?
Jerry
1990 Geo Tracker,  2-Door Hard Top
1.6L 8v, 4x4 Automatic, 0" lift
« Reply #3 on: August 25, 2004, 02:07:58 PM »
I had the switch do that, the solder comes
loose and just needs to be re soldered with
some silver bearing solder, as it has a higher
melting temp
Also you need to soldered it in the trucklet
as I don't think there is a plug for the switch
to be removed from the wiring harness
Good Luck
