LETS GO!
  • 9 Replies
  • 2039 Views
Offline r3cc0s
  • 321
LETS GO!
« on: April 22, 2005, 02:40:15 PM »
Offline purevil71
  • 261
  • Someday when I grow up, I wanna be hardcore too!!
Re: LETS GO!
« Reply #1 on: April 22, 2005, 02:42:47 PM »
wow...thats big!!!
88.5 Samurai
Balls Deep 4x4 & Off-Road
I-Zook Staff
Offline bandit86
  • 1641
  • elv8rguy
Re: LETS GO!
« Reply #2 on: April 22, 2005, 03:13:05 PM »
I dont think the factory strut mount is strong enough to support a v8 in a tracker.  it's nice, but you may wanna think about fabbing up some spring supports.   especially if your shocks are hooked up to the same thing.  What engine is that?
Other then that, it looks nice, put up pics of the rear suspension.
Offline r3cc0s
  • 321
Re: LETS GO!
« Reply #3 on: April 22, 2005, 03:23:24 PM »
1.6 16v  ::)
4 link in the back
« Last Edit: April 22, 2005, 03:25:17 PM by r3cc0s »
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
Re: LETS GO!
« Reply #4 on: April 22, 2005, 03:37:21 PM »
what are the tyres on the back called? i like them a lot. they look different from the ones on the front, but imagine them to be swampers of sorts.
thanks.
Offline r3cc0s
  • 321
Re: LETS GO!
« Reply #5 on: April 22, 2005, 03:44:10 PM »
look close
they're boggers with a a staggered strip of lug removed
Offline mesjr2004
  • 422
Re: LETS GO!
« Reply #6 on: April 22, 2005, 04:27:09 PM »
looks like a ford motor to me
Offline 37kicker
  • 319
  • 97 tracker 9inch front and rear on 40" pitbulls
Re: LETS GO!
« Reply #7 on: April 22, 2005, 06:17:41 PM »
302 or 351 even better  ;D what size tires 35 s or 39.5 s dosnt matter looks like fun to me. lets go play!!!!
Offline Chief
  • 678
  • Whaddya lookin at??
Re: LETS GO!
« Reply #8 on: April 23, 2005, 04:45:40 AM »
Reenforce upper coil buckets, add a snoprkal, and LET'S GO!!!!!
That things sweeeeeet!  8)
You got more pics of the cage? I Like that exo design!
« Last Edit: April 23, 2005, 04:46:14 AM by Chief »
Offline jagular7
  • 1026
  • Jagular7
Re: LETS GO!
« Reply #9 on: April 23, 2005, 01:40:50 PM »
As I own a Bronco, the frame looks Ford to me. Those spring buckets are definately Ford as well as those 3 bolts holding the steering box in. In the 2nd pic, you can see the engine crossmember. This used to be a 80-96 Ford 1/2 ton. The TTB (twin-traction beam) front axle was bolted to that beam. That little tube on the beam is the stock ps cooler.
The front axle is a ball-joint type and from the size of it, could be a D60. But look real close at that track bar mount on the axle. Very little bead I could see.
Also, not being anyway picky, but there appears to be an extra green tube bar. It's located in the 1st pic where the passenger foot well is. Nothing on driver's side to match.
Lenexa, KS
