Odd brake noise???
  • 1887 Views
Offline blacknight
  • 987
    • Gonzookin
Odd brake noise???
« on: January 27, 2005, 11:43:22 PM »
Im starting to get an odd noise from my front brakes between 10 to 15mph when coming to a stop and only when coming to a frim/hard stop.  The sound is like groan, just like when your on a hill and let the brakes out slowy. The streeing dosen't pull and it stops striaght.  I check the pad and they seam ok.  Any other thoughts??? Glazing, something lose???
George
« Last Edit: January 28, 2005, 02:01:59 AM by blacknight »
Re: Odd break noise???
« Reply #1 on: January 28, 2005, 01:57:32 AM »
Brakes, not Breaks  ;D
unless your brakes break, which is
what it sounds like you got.  Did you
check all front pads, inside and out ?
Hard Braking can cause the pad to contact
the unworn edge of the rotor, just a bit, so the
sound is intermitant, or did you just change
pads?  Just return from a trip where you were
braking heavily and got the pads smoking ?
That could be glazing
Offline blacknight
  • 987
    • Gonzookin
Re: Odd brake noise???
« Reply #2 on: January 28, 2005, 02:05:12 AM »
Sorry about the break brake thing alway mixxing them up :-/  The only thing that I have done to my brake is go to larger tires witch (j/k) I know is put more stress on them when stopping but me tire or only 30"
George
Offline SnoFalls
  • 1358
« Reply #3 on: January 28, 2005, 02:55:09 AM »
I had this causing a squeal when I picked up my trac ...
Offline blacknight
  • 987
    • Gonzookin
« Reply #4 on: January 28, 2005, 05:38:18 AM »
George
Man I really need to start reading what I'm typing before I post  :-[.
I think I will pull the brake pads off this weekend and give evething the once over. See what I find.
George
