different shift boot
  • 20 Replies
  • 2534 Views
Offline kirk70
  • 47
  • I love YaBB 1G - SP1!
« on: January 27, 2005, 07:28:18 AM »
putting a 3" lift on has caused some changes in my gear shift and the factory boot is in a slight bind.  where can i find a leather boot, or some other softer pliable material.
i would like somthing that will cover up the hole to keep the noise, dust, and cold air down a little.
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
Re: different shift boot
« Reply #1 on: January 27, 2005, 08:33:01 AM »
i used my factory shift boot. i cut it down bolted it to the floor plate, and bolted the floor plate to the floor. and i removed the center console.
« Last Edit: January 27, 2005, 08:33:30 AM by tracker8wr »
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline bandit86
  • 1641
  • elv8rguy
« Reply #2 on: January 27, 2005, 08:40:15 AM »
I have a 4 inch body lift, I used the shifter boot out of a mid 80s s-10 pickup, and the tcase boot from a 98+tracker.  works and looks great
Offline 92Sidekick4x4
  • 1456
« Reply #3 on: January 27, 2005, 10:24:45 AM »
i've seen soem that were made out of leather, i think they woudl work good i may get one cuz i got the same problem,
oh ya there at walmart
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #4 on: January 28, 2005, 12:01:29 AM »
Just put your stock boot back in upside down.  Works great.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
  • 1456
« Reply #5 on: January 28, 2005, 02:10:42 AM »
upsidedown?
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #6 on: January 28, 2005, 03:43:58 AM »
upsidedown?
Yup.. The inner (lower) boot.  You put it in upside down, and it telescopes right down to the transfer case.  Seals it up good, works great.
Bob
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #7 on: January 28, 2005, 04:49:50 AM »
Hey Bob, got a pic of your boots? I also remember you had a cool manual shifter setup with a cool knob. Wasn't it a skull or something?
Heather Galvin
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #8 on: January 28, 2005, 05:01:00 AM »
It's a Spidertrax Spider.
I'll see if I can hobble out to the rig, and snap a pic.  There are advantages to being home, sick!...
Bob
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #9 on: January 28, 2005, 05:02:03 AM »
That's right, a spider. It was neat. Beats my RockNob.
Heather Galvin
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #10 on: January 28, 2005, 05:11:15 AM »
Here you go!
You want my spider Heather?
'Cause I think I'm moving to a Hawk Green Shifter.
Bob
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #11 on: January 28, 2005, 05:20:48 AM »
I wonder if it will fit on one of my tcase shifters.. but I think I should probably actually "buy" something from spidertrax to make it "legal".
hmmm
« Last Edit: January 28, 2005, 05:21:25 AM by hcgalvin »
Heather Galvin
mudfkr
« Reply #12 on: January 28, 2005, 05:22:52 AM »
That looks like the way to go Bob,
I think I'll change mine around like that too now that I've seen how  simply putting it in upside down would have been so much easier than the shagging around way I done  it :-[
Funny how one never sees the easy logical solution while actually doing the job  :P
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #13 on: January 28, 2005, 05:24:06 AM »
Since we're on the topic of shifters,
Here's mine ;D
BTW all,
That's how a Kicker 3 looks installed with a sammy case.
« Last Edit: January 28, 2005, 05:25:24 AM by hcgalvin »
Heather Galvin
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #14 on: January 28, 2005, 05:24:17 AM »
Hey, I bought it from Spidertrax.  You can HAVE it if you want it.  Special offer, available only to YOU.  'Cause you're "special", don't you know!
Bob
