4.24.1 t-case x 5.12 x33's, is my gearing low enough?
  • 8 Replies
  • 1457 Views
Offline 96Kicker
  • 1043
  • http://www.zukiworld.com/forum/gallery/3710_25_10_
    • www.myspace.com
« on: April 23, 2007, 12:20:36 PM »
Im running a 8 valve tracker with 31's,4 to 1 t case gears and 5.12 thirds. I want to step up to 33's but are concerned about gearing being to high ??? with 31's and stock t case I was smoking my clutch every where(rocks ,no mud) who out there has a similar set up   that could give some advice on what size tire to run? 32's or 33's??????
<a href="http://s220.photobucket.com/albums/dd126/fletcher9160/?action=view&current=Zuktahgreenblur.jpg" target="_blank"><img src="http://i220.photobucket.com/albums/dd126/fletcher9160/Zuktahgreenblur.jpg" border="0" alt="Zuktah club sticker"></a>TJ
#801-554-3281
96 kick 4 door with custom 3 inch susp lift and pre runner front bumper,2 inch bod
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: 4.24.1 t-case x 5.12 x33's, is my gearing low enough?
« Reply #1 on: April 23, 2007, 12:32:19 PM »
In low range, with your new 4.24:1, you will have very few problems, if any.
I am currently running the 5.83 R&P's, and 33's with a 16 valve - so I've got two advantages - more power, and SLIGHTLY (13%) lower gearing.  I suggest you run the 31's to see what it's like, and then decide if you have enough oomph left to go to 33's based on YOUR driving style, and typical terrain.  You will probably NOT be happy with the performance on the highway, in high range, with the 8-valve, and 5.12:1 R&P's on 33's.  I know I'm not wild about MINE on the highway, with the 16-valve and 5.83's.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline 96Kicker
  • 1043
    • www.myspace.com
« Reply #2 on: April 23, 2007, 12:38:01 PM »
I realy don't care about the highway driving. I trailer my rig  to where I wheel. It realy isn't even street legal.
Maybe just get new 32's for now. Although I have plans for a kicker 3 set up and already have the sammy t case ;D. That would correct it all right there.
#801-554-3281
Offline copperzuk
  • 38
« Reply #3 on: April 23, 2007, 01:22:01 PM »
 I run 35" with that set up and it works fine, Ran 33's for 4 years that way.  Engine rev's 400 600 higher ( something like that)  at 55mph then a stocker.  You should be around 77:1 crawl ratio.
Offline 96Kicker
  • 1043
    • www.myspace.com
« Reply #4 on: April 23, 2007, 02:18:21 PM »
hey copper how was your low range,1st gear in the rocks? burn your clutch alot or no?
#801-554-3281
Offline Armour
  • 360
« Reply #5 on: April 23, 2007, 07:07:19 PM »
I have a friend running an auto with 5.12s, 4.24:1 t case and 35s and says in works great. I am going to do the same to mine. I run 5.12s. auto with 33s. seems to be ok climbing but is sluggish in the thicker mud.
89 Sidekick. 33's.  Lincoln Locker,4.24 T Case, 5.13 gears. Warn M8000 winch.
96 Tracker. 39.5's Locked 44's front and rear, 6.5 t case, 4.10 gears.
Offline copperzuk
  • 38
« Reply #6 on: April 24, 2007, 07:37:14 AM »
 Sorry, for some reason I thought you where running a Sami.. You should still be ok, I believe Mike ran the same gearing in the RockStar with the 35's and there's a few other guys in my club running 33's and 35's with that set up.  The auto's don't work as well as the 5 speeds down low even with 33's.
Offline 96Kicker
  • 1043
    • www.myspace.com
« Reply #7 on: April 24, 2007, 09:26:49 AM »
Hey copper that is exactly what I wanted to hear!! I will be going down to 4 wheelparts on friday to get my new 33-10.5-15 tsl radials >:D
#801-554-3281
Offline bzzr2
  • 1011
« Reply #8 on: April 24, 2007, 12:04:09 PM »
nice tire choice!  i love my tsl radials even though they are only 31's..
09 taco reg cab short box 4x4
