upgraded brakes
upgraded brakes
cincy_kick
upgraded brakes
August 12, 2007, 08:15:55 AM »
I just put 4dr front brakes on my 2dr. It was not as bad a I thought it would be. Had to do some trimming on the back shield to make the brackets fit. Since my brakes were crap before I dont know how big a difference this will make. Now I figure it is ready for a 2" spacer lift(which Jeff will send as soon as paypall gets him the money, and I have had great luck with in the past) then the bigger tires are going on. I should have enough brakes to stop from 80mph on the highway, which was my biggest worry.
derekj
784
i'm the canadian guy eh?
Re: upgraded brakes
August 12, 2007, 02:33:56 PM »
The brake upgrade makes a big difference in how the truck stops. The brakes have better heat dispersion due to the vented rotor. Once you have broken in the new pads you will feel the difference.
Derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
32" TSL's and some other stuff I did And now with a Lockrite!
www.cardomain.com/memberpage/783382
LilRed
930
3
Re: upgraded brakes
August 12, 2007, 04:06:48 PM »
I need to do this as I noticed a big difference in braking when I went to larger tires! Let us know how it goes!
cincy_kick
Re: upgraded brakes
Reply #3 on:
August 12, 2007, 06:07:16 PM »
I should have the lift and the bigger tires in two to three weeks. I will keep updating. I had a bango fitting leaking I found last night. a couple of new crush washers fixed that.
Yankee-Tim
562
Re: upgraded brakes
Reply #4 on:
August 13, 2007, 06:12:02 AM »
If anyone is thinking of doing this, a guy on Ebay sells zinc'd, drilled rotors for about $60 a pair, and get this, they are stamped "Brembo" right into the rotor edge.
Yup, drilled Brembo rotors for $30.
kingzoo
Re: upgraded brakes
Reply #5 on:
August 16, 2007, 06:41:49 AM »
m I bought my drilled and slotted Brembo's with pads on EBAY for about 100 bucks.They work great and look cool.
