Sensor dash light question
  • 1205 Views
Offline 144man
  • 85
« on: May 15, 2011, 12:20:59 PM »
My sensor idiot light came on at 60K, like the manual said it would.  I found the reset switch under the dash, and flipped it to the down position.  The light comes on when starting, but goes out.  Do I leave the switch in the down position, or return it to up.  The manual is unclear if I should reset the switch.
Forgot to mention, bone stock '87 Samurai.  And it passed PA emissions with the light on, so everything seems to be working.
Offline Capt
  • 738
  • 28
Re: Sensor dash light question
« Reply #1 on: May 15, 2011, 07:07:06 PM »
You are right the manual I also have is vague.......
I just left it in the opposite position as the light came back/ and stayed on when I flipped it back.
I think it comes on momentarily when you turn the key on as a system indicator check.
Hope someone that has more info responds and can give both of us a better clue!!
(P.S. I have just about all the ECU systems disconnected anyway as I have gone to a Weber Carb System)
CAPT
« Reply #2 on: May 17, 2011, 07:36:04 AM »
The sensor light lights up when the key is turned to run/start, to check the bulb, then it goes out once the engine is started, if there is no problem.  It is working as designed.
