>:(Warning!!! Soap Box Below
you get new shocks, springs and struts and takes less than an hour to put in. No additional parts needed like calminis. Seeing to many front diffs broke from calmini. ÂÂ
Where did you get your info of the Calmini Kit breaking breaking Diffs
I drove the hell out of mine for over 4 years with their kit and
never had a problem!!! The only thing that the lift has to do with it, is the fact that it allows you to install larger tires, that makes you want lower gearing and lockers, THEN you start breaking stuff, not because you installed a Calmini kit!!!!!!!!!!!!!!!!!!!!!! I think any one I have heard that has a negative comment of any sort, abiout Calmini always mentions how much
easier the other kits are. The funny part of it is that most of the people that use these rides for trail rigs on a regular basis almost always use Calmini and like their products.
If you dont want to break it, keep it on the road,
