HELP!!!
HELP!!!
Nicksidekickin
104
HELP!!!
February 15, 2011, 01:46:20 PM »
My zuk wont start!! It acts like it is cross wired check its ok. Starter works great, everything powers up, no blown fuses. any ideas to what it could be any help would be great.
1.5 coil spacers front and rear
custom rear bumper
windshield post lights
front push bar
electric fan
aftermarket exhuast
31x10.50s on 15x8s
1.5 body lift
bentparts
4536
60
I'd rather be Blown AND Injected.
Re: HELP!!!
February 15, 2011, 04:18:10 PM »
Have you done anything to it? when was the last time it ran and how did it run?
Nicksidekickin
104
Re: HELP!!!
February 15, 2011, 06:07:40 PM »
its been setting about 3 weeks finally got warm anuff to start working on it again.
custom rear bumper
front push bar
electric fan
aftermarket exhuast
31x10.50s on 15x8s
1.5 body lift
key4202003
36
Re: HELP!!!
Reply #3 on:
February 16, 2011, 05:19:36 PM »
i would start with charging the battery.
c3006
263
10
Re: HELP!!!
Reply #4 on:
February 17, 2011, 08:28:14 PM »
If the engine is cranking the first thing I do is hit the carb with a little starting fluid,if it hits and trys to run you have a fuel problem. If not I check the fire comeing from the coil going into the top of the distributor. Good luck c
Nicksidekickin
104
Re: HELP!!!
Reply #5 on:
February 18, 2011, 01:23:07 PM »
Im thinkin the fuel pump is gone out or a bad fuel filter
custom rear bumper
front push bar
electric fan
aftermarket exhuast
31x10.50s on 15x8s
1.5 body lift
BRD HNTR
2300
56
Re: HELP!!!
Reply #6 on:
February 18, 2011, 06:24:02 PM »
If the MAF is not connected/in place it won't run.
93 Tracker,XL7 springs & 1" raised spring pads in front with YJ springs in back, home built bumpers rear & front (w/winch), 2" x 4" rock tubes, ARB front & rear, converted Sami rear to IFS, 33x12.5x15 aluminum rims, roll cage, 2.7L w/5 speed auto.
idaholwb
772
2
And that's the way the metal crumpled!
Re: HELP!!!
Reply #7 on:
February 18, 2011, 07:00:52 PM »
You left out a few important facts... What year is it? What does it do when you turn the key? Does it turn the engine over? Does it act like it wants to fire? If it doesn't turn over, does it click or make any other noises? All need to be answered in one way or another...
97 Sport
265/70-16s
2" lift
2.0 swap
Skyhiranger
3734
122
I don't buy, what I can build
Re: HELP!!!
Reply #8 on:
February 19, 2011, 04:41:57 PM »
Quote from: BRD HNTR on February 18, 2011, 06:24:02 PM
What years are you talking about? I've left the MAF sensor unplugged on 92-95 trackicks and they will start and run (the CEL lights up, but it still runs).
