clutch adjustment
  • 1184 Views
clutch adjustment
« on: April 16, 2010, 04:54:43 PM »
I just put a new transmission in my 88 samurai and the arm on the outside of the transmission for the throw out bearing was taken off so i put it back on 90 degree's to the ground, put on the new clutch cable and hand tighten the adjusters and then gave it another 1/4 inch turn. The gears didn't grind when i put it in gear but the clutch engages close to the floor. When i put it in neutral it pulls a little bit and drops rpm's. I don't want to smoke my new clutch because i didn't adjust it right. Does any one know what i am doing wrong. Any help would be apprecited
Offline 89tracker43000
  • 47
  • my tracker
Re: clutch adjustment
« Reply #1 on: April 16, 2010, 05:55:19 PM »
im not sure if its the same on a samie as a kick but on kicks there is 2 dots that should be lined up where the arm goes on the spline shaft one on  the arm and one on the spline shaft. hope that helps
« Reply #2 on: April 19, 2010, 05:16:25 PM »
My samurai did have the dots underneath all the dirt thanks for the info. I lined up the dots, adjusted the cable as per ACK'S diagram everything seems ok but when i put it in neutral it pulls forward just a bit not enough to roll the truck but the rpm's drop a bit. It did it with the old clutch as well not really sure why it does this or if it is a bad thing?
« Reply #3 on: April 19, 2010, 05:29:48 PM »
Thick gear oil, when it's warm it shouldn't be it
