Cherokee vs Grand Vit
  • 25 Replies
  • 4995 Views
Offline RustyRed
  • 14
  • Newbie
« on: January 04, 2006, 08:34:47 PM »
Hey,
So here is my dilema: ??? I currently have a very off road capable 90 Jeep Cherokee that I spent a lot of money on (upgraded rear axle Ford 8.8, Detroit locker, disk brakes, 4.56:1 gears, custom rear bumper, 33 in. tires...).  The rear axle is my pride and joy, this is a bullet proof axle with a locker and disk brakes.
Now the XJ is rusting away, every year I have to cut and patch different body parts. Last spring I had to repair a huge hole in one of the "frame" rails. I HATE BODY WORK >:(
And I also own a 99 Grand vit that is currently bone stock.
So I am thinking about getting rid of the XJ and modifying the Zuki. Now I have been reading this site as well as others, I have read up on the problems with lifting the GV and the fact that it is IFS and will never perform (offroad) as well as my XJ. I know a SAS would probably solve this problem but I am not a good enough fabricator to do this and it would be too expensive to get someone else to do it for me. So I am basically stuck with a small 2-2.5 in. lift, and a body lift to get a maximum of 31 inch tires under there.
I am a member of an offroad club here in Ottawa, Canada and I don't want to go from leading the pack in my XJ to a much lower vehicle that will just barely make it on the local trails.
So what do you think I should do?
1 - Keep the XJ and keep on fixing it. Keep the GV stock as a DD
2 - get rid of the XJ, keep the parts (axle and tires) and get my self an old Trackick for off road use and keep the GV stock as a DD
3 - get rid of both the XJ and the GV and get myself an older Trackick as both DD and offroader
4 - Or sell the parts for all I can get for them and use the money to mod the GV and buy a winch to get me out of any stuck I find myself in.
BTW money is tight so I am looking for a cheap solution. I am sorta leaning towards #4 myself to get rid of the second vehicle, but I will never get as much money as I invested in the parts.
Is there any way to install my axle on the GV?
RustyRed
Offline keith
  • 1176
Re: Cherokee vs Grand Vit
« Reply #1 on: January 04, 2006, 09:14:32 PM »
Could you buy a cheap XJ with a decent body, maybe even a 2wd model.  Then move the parts from your XJ to the new one?  Personally I would want my offroader to be topless so I would want something where the top could be removed.
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
« Reply #2 on: January 04, 2006, 10:08:04 PM »
sorry, i know nothing about jeeps, but i would think short of getting another XJ with a good body and swapping the goodies over, would be option 2.
ok, maybe i also dont have an understanding on how much stuff over there is worth, but buying a swb track-kick-vit soft top would be reasonable, and just swap everything over. and maybe ultimately, sas it with the XJ gear.
GV as DD still.
the swb track-kick-vits are little weapons if you know what to mod. and they wont cost you the world eaither, so you can do budget lifts on them.
hope this helps.
Offline the_maplebar
  • 466
« Reply #3 on: January 05, 2006, 07:02:40 AM »
My vote is to go with #4.  Look around in the XL7 and GV forums, with a little trimming and the 2.5" + 2" lift people have been able to 32's.  Of course I do have an 02 myself so I want to see more people taking them offroad so we get more vendor support :)  Oh, do you have a 5spd with the steel front diff?  If so then your drivetrain should be stronger than a sidekick's already.
« Last Edit: January 05, 2006, 07:04:31 AM by the_maplebar »
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #4 on: January 05, 2006, 10:22:36 AM »
Oh, really?   8)
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline blacknight
  • 987
    • Gonzookin
« Reply #5 on: January 05, 2006, 10:52:25 AM »
Who in there right mind would off-raod an XL-7  ::)
pic at Paragon on PA with 225/75/16 and 2.5 Calmini lift
at Paragon again with 245/75/16 2.5 Calmini lift and 2" BD lift
more to come........
Offline RustyRed
  • 14
  • Newbie
« Reply #6 on: January 05, 2006, 01:08:12 PM »
Thanks for the replies,
You have all given me lots to think about. Blacknight and the_Maplebar this is sorta why I am kinda nervous about the GV is that there aren't many of them out there, and there are a limited number of aftermarket parts out there. I have been reading the XL-7, trackkick, and GV forums here and there is a lot of info.
I think I am going to look around for some donor vehicles either an XJ or a Trackkick (whichever seems to be the cheaper solution). BTW I am really quite impressed with the Trackkick, easy to mod and inexpensive, this sounds like a very good deal. I should have bought this instead of the GV.
 In Canada (Ottawa) everything is rusty, so to get something not rusty I will have to shell out more bucks.
Topless is good but I do quite a bit of winter driving, I just pull out the rear windows on the XJ to get the most air flow during the summer and reinstall them to have heat during the winter. And with the kid and 2 dogs I will have go with a 5 door Trackick unless I leave the wife at home and put the kid up front ;)
I think I am only going to do something in the spring so there is no real rush.
Bobzooki, It will take a lot of work to make an IFS flex as much as a solid axle. This not to say that a modded IFS isn't better that a stock solid axle rig. Show me some pics to disprove this  ;D And show me some Vit or GV pics if ya got 'em.
Thanks again
Rustyred
Offline bandit86
  • 1641
  • elv8rguy
« Reply #7 on: January 05, 2006, 01:45:03 PM »
take all the good parts and put them on the gv, axles, tranny everything.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #8 on: January 05, 2006, 02:04:01 PM »
Hello, RustyRed
I vote for #5:
Part out the XJ, buy a Samurai and put the XJ proceeds into it!  On the up side, stock Samurais are cheap, easy to maintain, have a solid front axle, have a lot of aftermarket stuff available including several engine (including Diesel!) and t-case upgrades.  On the downside, there are not many Samurais around as there used to be.
Second is #2.  There are lots of cheap TracKicks around for sale.  You CAN beef up the front IFS quite a bit, they have Fuel Injection, there are transfer case gear upgrades available.  I have to admit that I have wheeled my stock '96 Tracker only once (Disney Oklahoma) but I do know that there is a lot of info in the articles on this site that can help you get more offroading performance out of a TracKick... I've seen some fine examples owned by posters here at the annual ZookiMelt.    In the Suzuki World, TracKicks are the future...
Ack
Offline Dihnekis
  • 398
  • I love YaBB 1G - SP1!
« Reply #9 on: January 05, 2006, 02:17:07 PM »
I'd say stick with your XJ, and the grand vit. Use the XJ as a trail rig. The XJ is more capable than the grand vit will ever be without massive amounts of time and money put into it.
Even a trackick without heavy modification (calmini 3+3, front and rear lockers, tcase gears, toyota cvs maybe) would probably get outperformed by your current XJ.
With that said, if you just feel like something new, find a used 1995 trackick (my favorite, 16v but the best body style) and get to work on it. Maybe you could keep both your XJ and grand vit, and make the trackick into a little rock buggy or something.
A samurai is also a good choice. It is already solid axle and has more aftermarket support than trackicks. When I wrecked my tracker, I went out and looked for a samurai. I'm now putting my tracker engine into my samurai... and the samurai is WAY more capable than my trackick was (stock 2wd, so I guess that is pretty obvious)
If it were me I'd stick with the XJ and grand vit combo though.
Actually, I'd like to see a solid axle GV so try that.   ;D
1988 Suzuki Samurai
31" BFGs, SPOA, 5.14 Calmini Tcase gears, DOM cage, rock sliders, spidertrax wheels
1.6L, header, and 2" flowmaster exhaust coming soon
Offline Shattered
« Reply #10 on: January 05, 2006, 04:11:14 PM »
i think you should ship the jeep my way real real cheap as the shape not a concern , just for parts, and build up the GV
Offline jeffry
  • 87
« Reply #11 on: January 05, 2006, 06:43:48 PM »
do you have a link to any Ottawa wheeling pics?
The 5-door is quite a capable little beast. You may need to pick your lines more carefully, but I'll take mine anywhere I took my Land Rover Discovery with a two-inch lift and 32's. More reliable over the long haul, and much more economical. I have Rocky Road's 4-inch lift (2 inch body, 2-inch suspension) and 29-inch tires. I've been quite pleased with the results.
Unless you do really hardcore rock-crawling, these Zuks can hang with the big dogs pretty well.
Offline Dihnekis
  • 398
« Reply #12 on: January 05, 2006, 06:47:25 PM »
I agree. I don't know what it is about zuks, but for some reason they are way better off road than the sum of their parts. My zuk on 31" all terrains with a 1.3L was able to go everywhere and more that a wrangler with a 4.5" rubicon express lift and 33" pro comp X terrains and a 4.2L.
What makes them so good? Is it the light weight?
1988 Suzuki Samurai
Offline bandit86
  • 1641
  • elv8rguy
« Reply #13 on: January 05, 2006, 08:02:20 PM »
phisics 101.  less weight, less pounds per sq/inch on contact, acts like a tank.  and in 4 low, you have just as much torque.
Any questions?
Offline Dihnekis
  • 398
« Reply #14 on: January 05, 2006, 08:29:23 PM »
How do we have just as more torque?
And I guess all that makes sense.
1988 Suzuki Samurai
