Check Engine Light AND 100,000 at same time!?
  • 31 Replies
  • 4119 Views
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: Check Engine Light AND 100,000 at same time!?
« Reply #15 on: October 12, 2007, 10:13:57 AM »
But the light will come back after a few days.  You still need to fix the problem.  Sadly... :)
This is where you lost me:
What problem?
If you have an older truck with the switch, the light comes on when the odometer hits predetermined points at which time you reset it by moving the switch to the opposite position.
If you have an ODBII-equipped vehicle (which I think that you do not), the Check Engine light is extinguished by resetting the ECM with an ODBII reader or by disconnecting battery.
In either case, if a problem that triggers the Check Engine light (other than switch) is not fixed, then the light will come on again in a short period of time (minutes or seconds).
Referring to the original post at the top, you said that the light came on at exactly 100,000 miles.  That indicates to me that your truck (pre-1996 I bet) has the switch under the dash that will, when placed in the opposite position, will turn the Check Engine light off.  Further, if the light stays off, your engine is okay and you don't have anything to worry about if you perform regular maintenence and otherwise keep everything in good shape.
Hope that this helps!
Ack
Ira
« Reply #16 on: October 12, 2007, 11:27:42 AM »
What problem?
Thanks Ack! And yes--1995.
That's what confused me about that post:
It came on at exactly 100,000 miles, flipped the switch, and it hasn't come back on.
95 Tracker
« Reply #17 on: October 15, 2007, 05:05:53 PM »
on my geo i have a switch and it came on a few times and most recently it came on at 170000 miles on the dot and the switch did not turn the light off ill flick it a couple times and it dims the light a little but does not shut it off is there anything i can do to get the light off
Ira
« Reply #18 on: October 16, 2007, 06:04:57 AM »
Hey, 95--are we made in Canada?
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #19 on: October 16, 2007, 09:02:51 AM »
Not sure if this was mentioned or not, but if your CEL is on because of the mil duty switch, you won't be able to flash the CEL codes by shorting the connector by the battery. The main purpose of this, is so have to take your rig to the dealer for "service"  :P
95 Tracker
« Reply #20 on: October 16, 2007, 12:55:58 PM »
Not that i know of Geo is under General Motors and the one i drive has California state emissions and was bought new in New York
Ira
« Reply #21 on: October 16, 2007, 01:29:39 PM »
Check the right-side of the driver's door opening when you open the door.
Just noticed it yesterday:
Mine says "Made in Canada," with specs for the tires.
Maybe just the body was assembled in Canada?
I hope so. I want to impress my friends, and that sounds so much better than China.
Offline ack
  • 1659
    • Ack's FAQ
« Reply #22 on: October 16, 2007, 02:00:31 PM »
You might try disconnecting the battery for a minute.  Of course, you'll also lose the programming on your radio...  >:(
Ack
Offline ack
  • 1659
    • Ack's FAQ
« Reply #23 on: October 16, 2007, 02:04:01 PM »
Suzuki and GM went together in a joint venture and built the "CAMI" plant in Canada where many North American Sidekicks and Geo Trackers were built.  Google CAMI for more info.
Ack
95 Tracker
« Reply #24 on: October 17, 2007, 12:13:09 PM »
wow i have never paid attention to the sticker mine says the same thing.
i have also noticed what looks to be a mitsubishi logo on the EGR solenoid vacume valve
Ira
« Reply #25 on: October 17, 2007, 12:25:53 PM »
Thanks for the info, Ack! Cool to know!
And 95, if I had the SLIGHTEST idea of where the part you're talking about is located, I would look.
I'm lucky to be able to locate the TIRES.
95 Tracker
« Reply #26 on: October 17, 2007, 12:44:15 PM »
ya i did not know the name of the part until i looked at the diagram under the hood and it happened to be on the diagram i dont know if your car has it or not because mine has california emissions but its a black cap with a mitsubishi logo on it. its hard to miss it sits about 7in from the throttle cable toward the front of the car and sits higher than the valve cover
Ira
« Reply #27 on: October 17, 2007, 01:25:52 PM »
Throttle cable..valve cover:
Yeah, that helps me a LOT!
HAH!!!
I'll investigate this weekend, but I'm too excited about something else right now:
Just got a raise and $1,000 surprise bonus, going into my direct deposit Friday morning. So I'm taking off work Friday to buy my bigger tires first thing in the AM, then off to the mechanic for my spring spacer lift.
Life is good!
(Today anyway.)
Offline brentd27
  • 101
« Reply #28 on: October 18, 2007, 02:30:40 PM »
I think you're referring to the EGR Modulator.
mic
« Reply #29 on: October 19, 2007, 04:21:54 PM »
My light was on for a long time undid the access panel below the steering wheel stuck my finger straight down flipped the switch and no more CHECK ENGINE light thanks for the info.
