Mission acomplished!!! I've posted before and after pics in my post below, but some notes to anyone about to do the same thing :
1) Walmart rang up the 235 Uniroyal Liberator ATs for 70 bucks each, although the sign said $85. That's a good thing.
2) Not only does it look cool with the lift and bigger tires, but the ride is AMAZING compared to before. We did tire pressure to 50, per tire specs, and I LOVE it at this pressure. Real soft and smooth--not hard at ALL. Is it all that extra rubber under me which improved the ride so much? I mean, she's smoother than ever, and if you would call this bouncy at all, I don't care--I love it.
3) The old sleeve inserts on the shocks that you stick the lower mouting bolts into did NOT fit into my new Monroes--they were too big. Not only could we hardly get the old ones out, but you can see just by measuring that it ain't gonna work. Fortunately, my mechanic had these perfect steel inserts that he used to make the fit. Otherwise, using the old bolts, the opening in the new shock would be too big for the old bolt and it would rattle around.
At first I thought that maybe my existing shocks weren't the stock ones, and since we're all running such older trucks here, this may very well be the case for a lot of folks, so anyone else going to do this, take note!
My old shocks did indeed say Suzuki, but again, a "typical" past owner might have used Geo/Suzuki service, where they might have replaced it with the same shock more or less--but with a different bolt opening there. This is especially important to pay attention to because you can't widen the bolt openings on the truck at ALL to accommodate the new larger bolts you're gonna get with your new Crown Victoria size shots--there's simply no room, no more metal there to expand the hole. You GOTTA use your old bolts.
4) On the rear end, my axle ventilation hose (is that what you call it?) popped out from the center of the axle due to the lifting. On my model year, I guess the hose is a wee bit short. We simply flopped the bracket that supports it, and that gave us the extra 2" or so that we need to properly secure it.
5) We had to grease the front upper spring mounts and hammer in the spacers to get them in there. No big deal.
6) Haven't done the alignment yet, but my mechanic looked at it when all was done, took her for a ride, and said if she really needed an alignment, she only slightly needed it.
So what's my next step, especially regarding the aforementioned camber bolts?
This is all too cool, and I'm heading over to my coffee and cigs shop right now to show her off.
Edit posted a few hours later because I forgot about this before:
I swapped my brand-new 205 spare tire for a used 235 spare, just so I wouldn't have to BUY a spare. Well, the mounting bolts are too short to hold this 235, but all you have to do is flop the tire to epose the ""ugly" side of the wheel to the guy behind you. And since your old spare cover won't fit on this larger tire at ALL, I just picked up a replacement cover at Pep Boys for 15 bucks.
It ain't the most gorgeous fit you've ever seen because they ony had the size that accommodated up to 32" tires, too big for this tire, but for 15 bucks, I can live with it for now.
