cheapest way to get more power?
  • 8 Replies
  • 11802 Views
Offline zukzilla1662
  • 90
« on: June 18, 2006, 08:08:53 AM »
i have a 88 suzuki samurai with 34's and i need more power out a my 1.3? or just swap the engine.....how much hp can i make my samurai put out with mods?
Offline takai
  • 907
Re: cheapest way to get more power?
« Reply #1 on: June 18, 2006, 08:19:24 AM »
In the long run it will be probably be cheaper just to swap the engine. Then you can mod that engine.  ;D
'Cause, I am to misbehave.
« Reply #2 on: June 18, 2006, 11:42:36 AM »
You can also consider upgrade paths. Many things on the 1.3 and 1.6 are interchangeable. So - you could get a Cam ($100), header ($200), exhaust and carborator for the 1.3 that will all bolt up to the 1.6L later.
Of course - the CHEAPEST mods you can do - are just a regular tuneup. www.hawksuzukiparts.com has a great tune-up kit that comes with everything you'll need. Then check your timing, and valve lash (free labor).
Offline SnoFalls
  • 1358
« Reply #3 on: June 18, 2006, 06:22:55 PM »
huh??? many things are NOT interchangable from the 1.3 to the 1.6 ...
the most expensive way is to build up the 1.3, then decide you want a 1.6, and then be swirling your 1.3 upgrades ...
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #4 on: June 18, 2006, 07:11:41 PM »
I think he may have meant from the 1.3 8V to the 1.6 8V. The 16V are different and the 1.3  8V parts won't swap over.
Offline zutefisk
  • 124
  • yumpin yiminy yee viss
« Reply #5 on: June 18, 2006, 10:50:41 PM »
Do you have gears?
87 Samurai
  • 90
« Reply #6 on: June 19, 2006, 03:28:16 PM »
not yet what type of gears would i need for highway at 70 with 33's.... is that possible
  • 90
« Reply #7 on: June 19, 2006, 05:04:20 PM »
34's sry
« Reply #8 on: June 19, 2006, 10:45:53 PM »
My cousin has 33's with an 8:1 and stock gearing and cruises well down the road.  I'm not sure he takes it over 65, due to it being mostly run on the highway and not the freeways.
