catalytic converters
  • 15 Replies
  • 2388 Views
« on: December 04, 2005, 09:36:29 PM »
My catalytic converter is rattling pretty bad now :o. Who makes a good replacement for the stock one? I would prefer if it bolts right up to the original stuff but not a must.
Oh ya. Its a 92 jlx 4 dr.
« Last Edit: December 04, 2005, 09:39:42 PM by TonyBalgony »
Offline da_tub
  • 307
Re: catalytic converters
« Reply #1 on: December 04, 2005, 09:45:40 PM »
is it just the heat sheild rattling?  if so just take it off.. the hetasheild that is ..as for a direct bolt on .. thats a big not gonna happen.. sorry man .. front of the cat is welded on..as for a better freeflowing one.. any performace shop should be able to help you out..
91 four door ,and some stuff
Offline legionnair
  • 94
  • I hate working lets go wheeling
« Reply #2 on: December 05, 2005, 01:58:13 AM »
unless you live in cal or van dont bother just cut out the cat and put in a pipe
OOps, owell thats just the fender
Offline maybe2fast
« Reply #3 on: December 05, 2005, 07:28:31 AM »
she will run happier! if you just cut the cat off. trust me you will be happy with the difference...mpg too
Offline dwcrisp
  • 212
  • 98 Tracker 2dr, 1 1/2" spacer lift, 30X9.5 BFG MTs
« Reply #4 on: December 05, 2005, 08:14:08 AM »
Mine started rattling so I stopped at a local muffler shop and he did a couple of quick tack welds to get the converter back on it's mounts where it belonged and bingo! quiet ever since!
Offline Dihnekis
  • 398
  • I love YaBB 1G - SP1!
« Reply #5 on: December 05, 2005, 08:57:22 AM »
Will a muffler shop run an exhaust with no cat? I'm planning on getting my exhaust done after my engine swap and I don't have enough cash for a cat.
1988 Suzuki Samurai
31" BFGs, SPOA, 5.14 Calmini Tcase gears, DOM cage, rock sliders, spidertrax wheels
1.6L, header, and 2" flowmaster exhaust coming soon
Offline maybe2fast
« Reply #6 on: December 05, 2005, 09:13:41 AM »
as long as they didn't have to take a cat off, they shouldn't mind working on it
Offline roeman
  • 62
  • 1994 sammy!
« Reply #7 on: December 05, 2005, 10:10:52 AM »
does it effect the engine if you just replace the cat with a pipe?
There are no regulations on emmsionss here, i was just worried about back pressure and stuff?
1994 sammy
1995 Vitara 16v
Offline maybe2fast
« Reply #8 on: December 05, 2005, 02:16:44 PM »
it should run better
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #9 on: December 05, 2005, 07:29:23 PM »
It depends on the engine management.  If it's OBD-II fuel injected you're playing Russian Roullette by taking the cat off as the rear O2 sensor is after the cat.  OBD-I fuel injected the only sensor is in front of the cat so it won't know if it's there or not.  Mine happens to have been taken off by the prior owner for some reason but if/when I do exhaust work on it I will put a cat back on it.  Modern cats (as opposed to the bricks this thing came with and generally the 70's-early 90's) flow very well and don't hinder performance.  Not to mention here in the USA it's a FEDERAL law to have a cat on.  If your state says you have to or don't have to have it doesn't matter, the US Government says you do.  If a sharp eyed cop every notices it's gone it's your ticket to get.
Offline Blasted
  • 63
  • Yea.. its a Kick.. Keep dreamin.
« Reply #10 on: December 05, 2005, 08:57:28 PM »
No idea where you are.. But Canadian Tire sells a 2" in and out for $79.95 and up.  Mine was a high flow for $89.99
93 Sidekick 2Dr.  2"body lift.  30" Tires. 1.5" Coil spacers. 4 door coils. 2"strut spacers. K&N Factory replacement filter. 2.25" Cat back, with glass pack.  Custom ground High torque Cam shaft. And CB for talkin trash.
Offline bus_driver
  • 479
« Reply #11 on: December 06, 2005, 04:44:32 PM »
the only time a cat will effect anything is if you have a sensor (o2) after the cat if you do not take it off and enjoy mine runs nice but I cannot say anything on the mpg since it got cold here and I have a heavy foot in snow.... sorry,,
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline Dihnekis
  • 398
« Reply #12 on: December 06, 2005, 07:16:20 PM »
Considering my whole exhaust system will run about $200, I don't want to spend almost 50% of the price on something I don't need. Especially since I'm broke.
1988 Suzuki Samurai
« Reply #13 on: December 06, 2005, 09:05:23 PM »
Is it illegal to buy used Cats in other States too ???
I ask because it is here in Cal.
Offline tsanchez
  • 26
« Reply #14 on: December 07, 2005, 11:18:37 AM »
I bought a 2" Cat off e-Bay for thirty bucks
Works great
