carpet paint?
  • 8 Replies
  • 1894 Views
Offline sidekick101
  • 128
  • best site on the net
carpet paint?
« on: June 20, 2006, 11:11:34 AM »
i have the grey carpet on the inside but seein as its 93 its lookin a bit old and stained lets say lol. i was owndering if anyone has every spayed there carpet with that carpet and vinal spray paint? i wanna do it in black so the cars only 2 colors instead of 3 lol (picky that way) just wondering if it has ever ran on anyone or staind cloths? do it stay on and not rub off even when wet? thanx nick
1993 sidekick JX, 2 dr, soft top, automatic,
Offline fullsink18
  • 250
  • Wheel Me!
Re: carpet paint?
« Reply #1 on: June 20, 2006, 11:30:25 AM »
I did that to my accords tan carpet.  It works pretty good. Does not stain clothes well at least when its dry.  Never got it wet.  I will wear off in place where stuff rubs.  Like where my foot rubs the wall next to my gas pedal the carpet is back to its orginal color.
94 2dr kick 8v
-     Full set of Calmini's skid plates, calmini header and full exhaust, k&n filter, sky idler arm, calmini idler arm brace and truss with stabalizer, lock-rite rear locker, Calmini 3"  BL, 2" Digger Spacers, Shrockworks bumper, chicago electric 8,000lb winch, 31" Grabber AT2, 15x7 2
Offline crikeymike
  • 713
    • http://www.wazuks.com
Re: carpet paint?
« Reply #2 on: June 20, 2006, 12:33:53 PM »
I've seen it before matched to tan carpet in my old cherokee.  it worked well and you couldn't hardly tell as long as it's applied evenly.  Careful now though, cause someone will chime in here in a second and tell you to rip that carpet out, that it only causes rust...   I like it cause it's not so loud inside, and i don't fill it up with mud and water like some others do.
1993 4-door Sidekick
4.24:1 t-case
Offline SnoFalls
  • 1358
Re: carpet paint?
« Reply #3 on: June 20, 2006, 12:45:11 PM »
uhh, would that be me   ::)
I will chime in tho and say "rip that carpet out", and replace it with a DIY undercoat (aka herculiner), and then add in easily removable pads. For $40 or so, you can get the thick rubber mat used for pickup bed mats, cut that to a nice fit and get a nice black rubber floor that's easy to pull for cleaning.
 ;D
Offline SnoFalls
  • 1358
Re: carpet paint?
« Reply #4 on: June 20, 2006, 01:13:57 PM »
in a not so toungue in cheek suggestion ...
WHEN you pull the carpet (you will pull it to paint it right?) ... scrape off the "padding" since that's the sponge that holds water and promotes rust. Also, scrape free what's stuck to the floor as well. Then you can see if the floor is showing signs of rust. Any surface rust spots you see, wire brush it down good, and spot spray that with a rust inhibiting paint.
Up to you what to reinstall (it's your rig so your choice).
I've done this on 2 different rigs (both got herculiner). On one I cut the carpet to simply cover the tunnel between the seats, but left the floor with the herc, and then added rubber mats. The other is just herculiner at the moment, but I think I'll add some "truck bed rubber mat" cut to fit nicely.
Offline sidekick101
  • 128
Re: carpet paint?
« Reply #5 on: June 20, 2006, 06:02:54 PM »
i woudl just take it out and do ur suggestion btu i use it for more daily drving then off road so i wnat it to look somewhat decent lol. alreday get slack form driving it by people lol. anyways, i kwno theres rust infact i knwo of a hole so i was gonna fix the rust/ holes and then spary bed liner in to waterproof it then put the "new" carpt in. woudl that be ok or would the water still find a way to rust the shit outta my floor lol. it only gets bad whne i go hunting form being in the muddy feilds and ponds
Offline SnoFalls
  • 1358
Re: carpet paint?
« Reply #6 on: June 21, 2006, 10:18:17 AM »
I understand wanting to keep the carpet in a DD.
The carpet alone doesn't hold too much water and dries out, it's the padding underneath that once wet seems to stay that way FOREVER ... that's why I say scrape that felt pad off.
My water intrusion is usually from a longhaired shepard that like to wade in the mud every chance she gets. I pretty much HAVE to hose down my floor every other trip out  ;D
Offline urbanwheeler
  • 696
Re: carpet paint?
« Reply #7 on: June 21, 2006, 01:52:54 PM »
Does the rust under the carpet happen on california cars (ones that have been stored most of their life away from the sun and the elements, but was only used during the winter(aka my 1990 tracker ;D ;D) I was wondering if anyone makes a vinyl kit for it, because I dont know if rubber mats and bedliner would be too appealing to any female passengers I might encounter ;D, (although I think it would be a neat idea, but it is probably a lot noisier inside ;))
Re: carpet paint?
« Reply #8 on: June 21, 2006, 08:56:33 PM »
If you use that roofing tar stuff, it'll deaden some sound too. It's cheap at a hardware store.
