can i swap 92 and 96 tracker trans without mods?
  • 7 Replies
  • 1609 Views
Offline 89tintop
  • 356
« on: October 07, 2006, 08:20:32 PM »
I have a 92 4door sidekick with 28k on it but it was rolled and i just came across a 96 tracker 4door with a perfect body but a blown motor, my question is since they are both the same in everyway except that one is an obd 1 and the other is an obd 2, are there different hook ups for the trans and tcase or in other words will this swap be successfull with out any problems? i want to swap the motor trans and tcase all in one since the 96 doner has 188k and the 92 only has 28k with ice cold air.
91 kick 4 door 2 inch body lift, 2 inch spacer lift, 31's.
Offline Utah_Tracker
  • 179
Re: can i swap 92 and 96 tracker trans without mods?
« Reply #1 on: October 07, 2006, 09:49:10 PM »
Haven't done it but I don't see a problem as long as you switch everything over.  I believe that the 96' has some different computer hook ups so I'm thinking that the worse case senerio is that you may have to switch your instrument panal as well as the moter, trans, etc...
91 soft top Tracker, 3' Calmini Sup, locker around, Auto, & no Power Steering
GO BIG or GO HOME
Offline offlimits4wd
  • 76
    • offlimits4wd.com
« Reply #2 on: October 10, 2006, 05:07:50 PM »
you can doooooo it.........
Offline 89tintop
  • 356
« Reply #3 on: October 10, 2006, 05:12:37 PM »
i want to but it sounds like a pain, see if one of those hookers around there want to tackle it, i can come up with alittle cash and a running and driving samurai for wheeling with.
  • 76
    • offlimits4wd.com
« Reply #4 on: October 10, 2006, 05:16:56 PM »
we got the parts and some narly tools.....talk to chris?
Offline 89tintop
  • 356
« Reply #5 on: October 10, 2006, 05:19:21 PM »
ruff or the other one? i have ruffs number but not the other ones.
  • 76
    • offlimits4wd.com
« Reply #6 on: October 10, 2006, 05:21:52 PM »
RUFF ABOUT THE TOYOTA
Offline 89tintop
  • 356
« Reply #7 on: October 10, 2006, 05:24:09 PM »
he allready ordered the waterpump tonight and will be installing it on thursday. i will ask him if he wants a small project. ;D
