I’m trying to find out if the carrier is the same dimensions as later models or if it’s the differential and the carrier, and the gear set that is different, or all three. I know for sure the differential is slightly different, and the ring gear ID. If the difference is in the carrier then I don’t care what the ratio is, this would help as the 4.62 appears to be a “hens tooth” as they say.
