Camber Bolts...again
  • 8 Replies
  • 1744 Views
Offline museboy07
  • 641
« on: April 11, 2007, 04:18:47 AM »
HI i just posted a topic on wheather or not adjustable 1.75 degree - or+ camber bolts would align my track right with the 1.75in coil spacers.  Well i just looked on the package and it said there only adjustable up to 1 degree - or+...now will that be enough to align my track?
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
Re: Camber Bolts...again
« Reply #1 on: April 11, 2007, 08:39:47 AM »
dunno its going to depend on how far out it is... mine when I tossed in muy 3 inch coil springs was off, I got it close but not perfect, after about 50-100 miles of driving it was perfect...
Offline museboy07
  • 641
« Reply #2 on: April 11, 2007, 11:26:56 AM »
did you modify you struts or use camber bolts john?
Offline john1974
  • 617
    • Zuknation
« Reply #3 on: April 11, 2007, 11:29:05 AM »
nope I used camber bolts, I didnt realize it allrdy had camber bolts in it.. but tossed the new ones in anyway. I only had to do the driverside since the passenger side didnt seem off.
Offline john1974
  • 617
    • Zuknation
« Reply #4 on: April 11, 2007, 11:30:17 AM »
Also I forgot to add I got the driverside close to inline, but it was perfect... then I drove it a bit and it worked out, must have been due to my springs breaking in...
Offline museboy07
  • 641
« Reply #5 on: April 11, 2007, 08:22:28 PM »
did you just go by looks to see what the camber should look like? or did you get it aligned?
Offline john1974
  • 617
    • Zuknation
« Reply #6 on: April 12, 2007, 09:32:19 AM »
 Looks, I will be getting it aligned soon anyhow.
Offline Jecky4x4
  • 22
  • 4x4 for life
« Reply #7 on: April 13, 2007, 09:33:01 AM »
the company for changes camber/caster up to +-1.75 degrees:SPC
part no': 81250
www.specprod.com
Offline BigPig
  • 276
« Reply #8 on: April 13, 2007, 02:48:23 PM »
SPC part # 81250
www.specprod.com
I got them elsewhere but same product number and they work great on my 5+ inch lift with 31's.
'89 Sidekick w/ 4.5" of lift.
