Do i need new motor mounts?
museboy07
641
April 09, 2007, 11:37:43 AM »
Hi guys, I can put my hand on the intake pipe and push my engine back and forth almost and inch. I thought it was my tranny mount so i changed it but no difference. Also when i shift and let the clutch out i can feel my engine and tranny jerk real hard. Also when i just rev my engine it moves back and forth almost an inch.. Do i need new motor mounts?
Quaddawg
1622
Flex and Ground Clearance is HIGHLY overrated!!
Re: Do i need new motor mounts?
April 09, 2007, 12:05:32 PM »
Sounds like you might, but an "inch" isn't a lot of movement, chances are, when under load, it is moving more than that. They are pretty easy to change.
museboy07
641
April 09, 2007, 07:20:52 PM »
ya i know there easy to change...im the one who put the motor in my kick, but does your motor move like that with just your arm strength?
