www.usedvictoria.com/classified-ad/1082444890 WHITE SUZUKI SIDEKICK JLX 4X4 2 DR 5 SPD. PARTS CAR. jlx is very rare in 2 dr model
THE DASH IS RIPPED OUT AND ENGINE,INTERIOR AND COMPUTER JUNK IS ALL OUT. THIS KICK IS REALLY JUST GOOD FOR PARTS.
SPARE PARTS LIST:
2" SUSPENSION LIFT WITH CAMBER BOLTS,CROWN VIC SHOCKS AND FLIPPED STRUT MOUNTS
2" OR 3" BODY LIFT BLOCKS WITH 2" EXTENDED SHIFTERS (HOME MADE) BUT WORKS!
FOUR DOOR SPRINGS. ANOTHER SWEET MOD!
SPRING RATE INFO:
2 DOOR 452.8PPI FRONT 156.5PPI REAR
4 DOOR 508.7PPI FRONT 177.9PPI REAR
2 1/2 5 SPEED TRANSMISSIONS/TRANSFER CASES
TWO STARTERS, ONE NEEDS BRUSHES
EXTRA COMPUTER AND JUNK
TILT STEERING COLUMN WITH CRUSE CONTROL AND INTERMITTENT WIPERS
POWER STEERING PARTS: RESERVOIR, PRESSURE HOSES, GEAR ASSEMBLY, PITMAN ARM. JUST NEED PUMP
NEW CLUTCH
TWO SUZUKI SIDEKICK STEERING WHEELS
MODIFIED REAR TAIL LIGHTS WITH HALOGEN HEADLIGHTS. FINALLY YOU CAN SEE IN REVERSE:)
FRONT SKID PLATE
BIKINI SOFT TOP. ALL IT IS REALLY IS A NORMAL BUT CANVAS SOFT TOP THAT HAS THE ZIPPER OUT SIDE WINDOWS. I LEFT THE BACK BAR OUT AND WRAPPED THE REAR POST FABRIC AROUND THE ANGLED TENSION BAR. SIMPLE YET EFFECTIVE.
I'LL TAKE A PIC!
I'M KEEPING THE WHEELS, FRONT BRAKES, FRONT 3RD'S, REAR END AND AXLE. FOR NOW
I'LL POST MORE STUFF AS WELL PICS.
IF YOU NEED SOMETHING, MAKE AN OFFER!
QUESTIONS? JUST ASK!
I'M EASY GOING, ZUKHEAD'S
TIM
