What size tires
  • 7 Replies
  • 2161 Views
Offline Dusty
What size tires
« on: December 18, 2003, 04:40:29 PM »
I have been researching tires for my 92 tracker and I have finally decided on BFG AT's.  My delema is that I can't decide what size.  I use the tracker every day to commute to school and go off road hunting/fishing/exploring about once a week so I do a fair amount of both on and off-road driving.  I don't want to buy new rims.  I do have 1 1/8" coil spacers flipped stut and longer shocks.  I can't decide on the 215-75-15's (diameter 27.8")which are almost the same size as the stock tires or the next size bigger which is the 235-75-15's (diameter 29") they would definately look better but be crammed on the rims.  What kind of difference in handling, performance, and gas milage should I expect between the two, my beloved 8v 1.6 tracker is a bit underpowered as it is.  Any first hand experience and advise is worth its weight in gold to me so thanks in advance.
Offline standog
  • 111
Re: What size tires
« Reply #1 on: December 18, 2003, 10:13:46 PM »
I just put 225/75/15 Dunlops on my 03 Vitara and am very pleased with them. They are like 28.34inch or something like that. Good luck.
« Last Edit: December 18, 2003, 10:14:57 PM by standog »
Offline van7559
  • 145
  • I'll Leave Tracks All Over Your As$
Re: What size tires
« Reply #2 on: December 19, 2003, 03:07:33 AM »
Go with the 235's that s what I have on my stock tracker and i do the same thing as you when it comes to wheeling. I live in CO and there are some big hills out here and my gearing went down to about 4:80 but it really isn't that noticiable. If you have an auto tranny I feel sorry for you.
95' Kick with a 3 in. body lift and plenty more to come!
Offline mahimahimo
  • 377
Re: What size tires
« Reply #3 on: December 19, 2003, 03:10:07 AM »
dan...the 235 75 r 15 fit wtih out rubbing on ur stock tracker?
Offline Z3bra
  • 273
Re: What size tires
« Reply #4 on: December 19, 2003, 03:44:59 AM »
I'd go with the 235's.  The difference in drivability between the two isn't all that much, but if you need to replace a tire in an emergency situation 235's are much more common than the 215 is going to be.  That way if you had to get a used tire in a hole in the wall sort of place that's not an offroad design just to make it home you're much better off. A lot of small trucks use the 235s.  Same reason I'll probably stay with 31x10.50's instead of 32x9.50's or 33s.  31x10.50's are a dime a dozen comparatively.
Either one should fit ok on your wheels even if they're stock ones.  Plus since you do offroad it a little bit you'll gain a smidge more ground clearance with the 235's which isn't a bad thing.  Heck I'm getting close to 11 inches of clearance on mine just from throwing the 31's on it without a suspension lift installed yet.
Absolute worst case you could get the U.S. wheel steel rims from summit racing for about 40 bucks each for 15x7's and summit also has free shipping which on a set of wheels probably saves you 25 bucks right there.  Sure they're not the greatest rims in the world but they do the job.  There's also the American Racing ones and so on.
I think the ones I have are 2 1/2" or so backspacing which is just the default setup for the 5 on 5.5 lug pattern version of em.  As it is now,  I just barely rub the frame rails with the 31's at full lock on the steering.  With the 235s you wouldn't run into this though since I had 235's on those rims before and it definitely wasn't a problem.
I see you're in vegas which is probably a big enough city to have some used wheel shops around, might be worth a look although I found here in Phoenix that the used ones were generally selling for 25 bucks or so per wheel for used steel oem or otherwise.  I figured screw it and just bought new ones.
Absolute worst case, without a body lift but with the spring spacers you have you still might run into some rubbing at the back of the front fender with the wheels turned when the outer edge of the tread is closest to the back of the fender. That's easily fixed with a sawzall or snips, or if it's just barely touching a bit of assistance from a hammer should do the trick and you can do it so that it isn't visible on the cosmetic part of the fender.  (had to do it for my 31's since I've only got the body lift for now.)
Oh and Van, with the auto even on 31's it's not all that bad, plus there's a nice trade off of lower engine RPM's on the freeway.  Granted I've also got the Hawk Suzuki Cam, the head and intake manifold portmatched to the gasket, .030 over pistons, .020 milled off the head, and a header and 2" mandrel bent exhaust with a straight through muffler.  I've been tempted to put the factory size tires and wheels on it just to see how it is since I've got all that finished but figure it'd look pretty lame with the body lift and no bumper covers.  Seriously though it's not all that bad.  (still wish I could swap it for a 5 speed though since I friggin hate automatics).  The lower rear end gearing is mostly there so the 1:1 ratio of 3rd gear is about the same as when you're in 5th with the manual.  (works out to about a 4.40:1 final drive ratio with the manual vs the 4.62 with the auto)
So to conclude: get the 235's and if you can possibly spring the extra 200 bucks or so get some 15x7's too.
« Last Edit: December 19, 2003, 03:45:54 AM by Z3bra »
Re: What size tires
« Reply #5 on: December 19, 2003, 06:41:26 AM »
I have 225/75/15 Dunlop p-metric rovers.
Good aggresive tread, and I do alot of highway driving.
They are great.
Offline wuggie
  • 40
  • I love YaBB 1G - SP1!
Re: What size tires
« Reply #6 on: December 20, 2003, 10:59:56 AM »
Yo guys, I have an "03 2 dr Tracker, auto, can I put 235/75-15 on w/o any problems?  Rubbing, loss of power etc?
Offline mahimahimo
  • 377
Re: What size tires
« Reply #7 on: December 20, 2003, 03:37:28 PM »
z3ebra u solved my problems of me thinken that the 235 75 r 15 would rub on a stock 94 tracker.... lol im gonna place the order for em wit a set of mickey thomopson classic 2 wheels
