do D 44's or a 9 inch or something. if you break your shafts that often get something where you can run a 31 spline axle shaft and a good strong ring, pinion and spider gears.
no use messing around with light stuff if it breaks all the time. if you have leafs it should be moderately easy to weld some perches on some new axles and bolt em on
