What other manufacturers wheels fit on the tracker
  • 6960 Views
Offline skidr1
  • I love YaBB 1G - SP1!
« on: February 23, 2004, 03:15:29 PM »
Does anyone know off hand which manufactures stock wheels will fit the tracker/sidekick?  My local Pennysaver and auto trader type papers are full of take off wheels:
Jeep Wrangler and cherokee
chevy 5 lug truck wheels
ford five lug trk wheels
etc.  Are the bolt paterns right on any of these?
Offline 92Sidekick4x4
  • 1456
Re: What other manufacturers wheels fit on the tra
« Reply #1 on: February 23, 2004, 03:31:15 PM »
yep i think the ford 5 lug nut will fit the ford f-150's are 5 on five and a half i think and they fit sidekicks
Offline Kreg
  • 795
  • Yo Ho, Yo Ho, a four wheelers life for me.
    • Island 4x4
« Reply #2 on: February 23, 2004, 05:13:54 PM »
ya they do.
I know Mac is running ford rims.
Offline jerryp58
  • 449
« Reply #3 on: February 23, 2004, 09:12:23 PM »
I think the Wrangler's are a bolt on too.
Jerry
1990 Geo Tracker,  2-Door Hard Top
1.6L 8v, 4x4 Automatic, 0" lift
Offline Cowtracker
  • 39
« Reply #4 on: February 23, 2004, 09:24:54 PM »
You are looking for 5 on 5.5" wheels.
Ford F150 trucks used these up until around 95 then they went to a metric size,  also full sized Jeeps... whatch out for the newer models, most use 5 on 4.5" wheels
later model dodge trucks(mid to late 80's and up) also use the 5 on 5,5" bolt patern.
be sure to check the center hole  and back spacing
too .
« Last Edit: February 23, 2004, 09:26:25 PM by Cowtracker »
Guitars,zukes and hilbilly music!
« Reply #5 on: February 23, 2004, 09:33:26 PM »
1-Jeep Wrangler and cherokee
2-chevy 5 lug truck wheels
3-ford five lug trk wheels
1- Nope, the wrangler and cherokee will not fit. The CJ rims will fit though
2- I'm not sure about this one but I'm thinking no.
3- Yep, these will work on the older Fords. Just check the lug spacing for 5 on 5 1/2 and make sure the center hole is larg enough for your hub.
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #6 on: February 24, 2004, 02:58:38 AM »
Hey, new black steel rims aren't that expensive.  You might be better off that way.  You can even custom your own back-spacing if you want.  It just takes a little more time.
96 Tracker
32 MTR's Warn 8000i
