"creeking noise"
  • 1227 Views
Offline trackenator
  • 38
  • I love YaBB 1G - SP1!
"creeking noise"
« on: May 13, 2005, 12:43:25 PM »
hey group. thanks for all your help. heres another ?. after i installed my tj spacers on my 92 tracker(2in) when i start to move or turn the wheel i hear"creeking" sounds from the springs(i think) . any idea y? is it just the sound of spring on the spacers?also previously i mentioned my tires tilting in after driving but out when i backed up. everyone said i should have been leaning out after the lift but im not . in fact i just re adjusted by pulling the tops out and tighting my strut bolts when i got my wheels "level"(by using a level) and she handels and rides better than ever. any ideas why mine was different than others? thanks
  • 6551
  • 64
Re: "creeking noise"
« Reply #1 on: May 16, 2005, 01:51:48 AM »
I don't think it is different than others. It sounds like you may have a toe and/or alignment problem which may be caused by worn out front end parts. Inspect stuff and pay close attention to the idler arm.
Good Luck, Eric
Offline trackermad
  • 150
« Reply #2 on: May 16, 2005, 02:48:45 AM »
Your springs don't turn when you turn the wheel so you should look elsewhere for the source of your creek.
Places to look: (anything that moves when you turn)
Worn out strut mount
bad strut
bad ball joint
steering linkage; Tierods, draglink, idler arm
Also check to see if you have any bent steering components that may be rubbing on somthing.
I'm sure I missed some things but those are good places to start.
"First of all: what is work? Work is of two kinds: first, altering the position of matter at or near the earth's surface relatively to other such matter; second, telling other people to do so."  ~Bertrand Russell
Offline Natebert
  • 1098
« Reply #3 on: May 16, 2005, 04:40:06 AM »
Body mounts often squeak, especially if you have a body lift.
Offline bus_driver
  • 479
« Reply #4 on: May 16, 2005, 07:39:34 AM »
I also have just recently got creeking noise so I wll chek those places as well ( no lift or anything ) thank you all
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
