I did my searches here so I already understand that I should replace me heater blower resistor, but I can't find the dang part anywhere--95 Track. (HELP!?) Here's my deal:
I know I have a slow leak in my AC system, but I now have the capacity to at least charge it properly and pump out the system clean between charges. (A friend.) Prior, I just kept shoving more 134 in there, which left all of those deposits. My leak is somewhere real expensive to get to, it seems.
Anyway, my two highest fan settings work, but not the others. Also, the green AC light only lights at the highest settings, and I see this is a symptom of the resistor. However, another poster indicated that his blows like a hurricane at the highest setting, and mine sure doesn't. Real weak.
I don't even CARE that it only works at the two highest settings, because with the heat down here and a ragtop, I need that anyway. But there's no chance that the current resistor is limiting the amount of blow, and that a new one will fix this, right? I think I read that at the highest settings, the resistor is bypassed anyway.
So should I consider a new blower motor? They're not very expensive "without wheel," but what does that mean anyway?
I did ten million searches for the resistor--even searched under Sidekick because someone indicated one or two sellers didn't have the part listed for the Track--but nothing is coming up.
I really wanted to get on this this weekend, so any help you can throw my way, thanks!
