I talked to the yard again they said its a 2003 XL-7 Vitara, with 5:13 gears (auto). They also said its steel. I`m going to take a magnet when I go look at it.
They are easy to tell a part as theres slight differences between the steel and alloy heres what to look for ..
The middle one is alloy and outer ones steel.
The Alloy has an extra gusset under the long side and four bolts on the end vs three bolts on the steel one.
Steel has four bolts vs three bolts for the alloy on the short side (you'd figure it would be the other way around
The alloy is filleted behind the short side mount and the steel is solid (once again you'd think it should be the other way
HTH Mudfkr
