Richie rich
  • 1587 Views
Offline bus_driver
  • 479
Richie rich
« on: December 22, 2005, 11:27:34 PM »
ok is there any way to adjust my fuel delivery on my 1.6 cuz it is sending raw fuel down the pipe until it is up to proper running temp. it has only started since we dropped below 0 degrees and now my km/ltr are shite went from 400kms on 33litres to 280km/ 33 litre
but when I warm it up real good and highway drive it for a longer period  it does better
now I know that it will go down in winter but that is a hell of a lot a difference  any suggestions?
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
Re: Richie rich
« Reply #1 on: December 22, 2005, 11:31:22 PM »
Hey that 280km/33 litre is my fuel consumption with 33"s  ;D. If your 'check engine' light is on it's probably the O2 sensor, mine had similar f c stock with that thing broken. ;)
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline ZeusZuki
  • 411
Re: Richie rich
« Reply #2 on: December 22, 2005, 11:43:48 PM »
Dude, sorry I cant help out here but I know members will want to know if it is a 8V or 16V ;)
Good luck.
I suspect some little component somewhere is not behaving >:(
Re: Richie rich
« Reply #3 on: December 23, 2005, 12:35:20 AM »
The PTC is probably not heating up.
PTC is Positive Temp Coefficient, it
looks like a basket that hangs under
the TBI and helps the low temp driving
Offline bus_driver
  • 479
Re: Richie rich
« Reply #4 on: December 24, 2005, 12:14:38 AM »
hey wild is that the wax ball thingy that acts like a choke????
if not  how does it work and how do I fix...I have no engine light so I assume there is no sensor problem.
it has been warmer the last couple of days so I will get more than 300kms on this tank
92 2dr soft top
235/75/15
2 inch lift
custom mud
Re: Richie rich
« Reply #5 on: December 24, 2005, 12:35:25 AM »
No, it looks like a basket hanging under the TBI,
the fuel and air flow thru it and get warmed for
cold weather driving, the PTC fits between the
TBI and the intake manifold, has a gasket on
both sides and has an electric plug on it (12V)
Offline derekj
  • 784
  • i'm the canadian guy eh?
Re: Richie rich
« Reply #6 on: December 24, 2005, 12:20:51 PM »
check your coolant temp sensor - if slightly out of range will send false signals to the computer and use more gas.
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
