16v timing blet replace ???'s
  • 1359 Views
Offline Jookycola
  • 372
« on: July 10, 2005, 08:32:52 PM »
so not too long ago....well almost 2 years ago actually.  I remember a post on here about how to replace the timing belt on the kick's 16v motor.  it was my understanding that this was actually a VERY easy fix...at least much easier than i had expected.
Something along the lines of once you get everything out of the way, just slowly pull the old belt off and try not to move anything. Then just slip the new one on.  Did i read that right or is there more to it?
  [/url]
Re: 16v timing blet replace ???'s
« Reply #1 on: July 10, 2005, 08:38:06 PM »
Come join the chat room.
Right now every body thats on is over there.
Just clink on the Chat button  above
Somethere will know
Offline Jookycola
  • 372
« Reply #2 on: July 11, 2005, 10:48:28 PM »
Oh POOP!  i wish i saw your reply earlier, i will do that tomorrow.
  [/url]
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #3 on: July 12, 2005, 06:54:06 AM »
It's pretty easy - well, except for those stupid bolts on the crankshaft pully, if I remember right.  I know for one part, I was using a mirror to FIND the bolts, to remove them.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
« Reply #4 on: July 12, 2005, 06:54:35 PM »
Those little crankshaft bolts are a 5mm
hex head, at least on the 8V engines.
I only put 3 of them back in, as there are
5 total, and they can be a pain to get out
Offline Speedracer7c
  • 2210
« Reply #5 on: July 12, 2005, 08:13:27 PM »
I did the timing belt on mine and it was a piece of cake. Just unbolt the fan, unbolt the fan shroud, and unbolt the nut in the center of the timing cover, take the bolts out of the crankshaft pully, they are 8mm. Then take the bolts for the timing cover off. Unscrew the stud on the tensioner pivot thingy, and the belt will fall right off.
