what crawl ratio
what crawl ratio
tracker8wr
568
THE BIGGER THE BETTER
what crawl ratio
July 06, 2004, 09:44:28 AM »
i have a 94 tracker on 31's and a 87 sammi on 32's. i am wanting to know what the 4low ratio is.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
http://www.geocities.com/race8thwonder01/
http://www.cardomain.com/memberpage/769479
okezuki
51
Re: what crawl ratio
July 06, 2004, 09:57:04 AM »
If you have sticks it`s 1stx tcasex axle. Ex--- 3.65x6.1x3.73=83.05low range. Tracker axles are either 4.62 or 5.12. Hope this helps.
87,33`s,6-1 t-case,d.c.drive shafts,locked,m/l with cj`s,dt8000`s,& the will to BEAT THE SNOT OUT OF IT!
cj
1276
I drive a really big ATV
July 06, 2004, 10:53:37 AM »
Tracker low is 1.816:1
Sammy low is 2.268:1
Last Edit: July 06, 2004, 11:16:43 AM by cj
tracker8wr
568
Reply #3 on:
July 06, 2004, 12:32:56 PM »
thanx
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
1bigtracker
3409
F*** trail rated, try trail tested
Reply #4 on:
July 06, 2004, 01:26:10 PM »
whats first gear in a tracker?
stu
 ÂÂÂÂÂÂÂ
cj
1276
Reply #5 on:
July 06, 2004, 05:23:47 PM »
Tracker first 3.65:1
Tracker diff 5.125 manual, 4.62 auto(4.30 Cali)
tracker8wr
568
Reply #6 on:
July 07, 2004, 02:46:37 AM »
i have 5.12 gears in the traker and am not sure about the sammi it is a standard.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
okezuki
51
Reply #7 on:
July 07, 2004, 04:32:37 AM »
Sammy first--3.65. Sammy rear--- 3.73.
