speedometer cable replacement...
  • 8 Replies
  • 1785 Views
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« on: January 14, 2006, 06:18:17 AM »
The '96 Tracker is making a lot of noise in the dash gage assembly that I think is caused by the speedometer's drive cable rubbing against the inside of it's cover.
Is it possible to fix this without having to replace the entire assembly?   Perhaps pull out the drive cable from the transfer case end and slide in a new one?
Ack
Re: speedometer cable replacement...
« Reply #1 on: January 14, 2006, 04:29:24 PM »
You can try pulling out the instrument
cluster, and putting some light machine
oil, like 3in1 or sewing machine oil, it
will creep down the tube and quiet things
up, if thats the problem. ATF would probably
also work if you don't have any of the other
stuff
Offline ack
  • 1659
    • Ack's FAQ
« Reply #2 on: January 14, 2006, 04:57:37 PM »
I was thinking of sliding out the cable from the T-case end, inspecting it for damage, loading it up with Lithium grease and then re-inserting it.  However, the laws of physics probably won't be in my favor with that procedure.   To be honest, I need a break from dash disassembly after removing and re-installing the multi-switch assembly this week >:( .
Thanks!
Ack
« Reply #3 on: January 14, 2006, 05:24:58 PM »
The speedo assembly is easy,
just the screws around the frame
and screws on the assembly, like
6 or 8 in all
Don't use grease unless it is specified
for speedo cables, most of the time it's
too thick and will cause cable wrap up,
especially in cold weather
Offline trup
« Reply #4 on: January 15, 2006, 04:22:42 AM »
i'm having problems with my speedo too, after months of broken cable, i decided to put new ones, and at speeds of 60km/h or higher my speedo will start to make a whining noise then my reading will jump to around 110 km/h :o :o :o, but below 60 everything is fine :P
« Reply #5 on: January 15, 2006, 11:53:45 AM »
lube the tube
Offline Carnage
  • 2453
« Reply #6 on: September 16, 2008, 10:32:32 AM »
im having trouble with my 96s speedo-cable now
do i really have to pull the steering wheel to get behind the dash to grease the cable
i tried going through the firewall AND the tranny but it doesnt seem feasible
« Reply #7 on: September 16, 2008, 01:02:45 PM »
I am currently getting a lot of noise in the dash and the speedometer used to bounce around a lot.  When I pulled it apart I found out the speedometer was broken, not the cable.
95sidekick
« Reply #8 on: September 16, 2008, 07:34:47 PM »
ive had quite a few of sidekicks at work where the lil gear in the speedo head would strip an cause this problem ....it also happend on my 4 door changed the speedo now noice is gone an have lower mileage haha  ::)
