when you drive your tracker it creates heat without a vent it would create pressure and blow out the seals
Quote from: backyardbuilt on December 01, 2008, 04:40:21 PMwhen you drive your tracker it creates heat without a vent it would create pressure and blow out the sealsPeople also add a hose to keep water out of the axles during deep crossings.Amilla
You mean that w/out the hose my axels are in risk of become full of water?
Check out these! There from ATV's and alot of the guys around here run them. I'll be using them in my current build.http://www.trail-gear.com/diff-breather.html
