Does anyone know of an OME spring that will fit the Calmini 3" susp lift
  • 1102 Views
Offline RJkick
  • 631
My rear springs fully compress which makes for a sometimes bone jarring ride
I was curious if a XL7 or some other model would give me 3" in my '92 4dr sidekick - nothing heavy up front and only a full size spare and some supplies in the rear.  I took everything off the rear and they still fully compressed so I need a change.
After such a sales job would anyone be interested in the springs after they are replaced?
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Re: Does anyone know of an OME spring that will fit the Calmini 3" susp lift
« Reply #1 on: February 10, 2009, 09:33:05 AM »
If your springs are bottoming out after a long ride or heavy use it's probally your shocks fadeing. I run my kick very hard in the desert and find that the springs are fine, just the shocks that Calmini sells w/ the 3" kit are not good for everybody. I run Doeshtec 8000"s they are hard for some but I can ralley at 50mph all day>
    Kevin
Offline nicker43
  • 15
« Reply #2 on: February 10, 2009, 09:59:28 AM »
I also have the same problem.  I have a Trail Tough bumper, cargo rack, and fuel and water canisters in the back.  I have to take it very easy over bumps to prevent the back from bottoming.  Does anyone know the Calmini spring rate?
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #3 on: February 10, 2009, 12:27:34 PM »
The front is 520 and the rear is 200
Offline skitime
  • 302
« Reply #4 on: February 10, 2009, 12:37:19 PM »
I was running 2" Calmini  springs in the back of my 2 door but one broke because they fully compressed. After that I cut the 3" spring that came with the 3" suspension kit I had on the Tracker.  That spring never gave me any problems and rode nice after cutting it.  Since then I changed to rear to OME 955 springs with a 1 inch spacer.  The 955 spring is the longest listed for the rear of a Sidekick and is listed as a 4 door Trackick medium duty spring. No heavy duty spring is listed at all for the rear.
« Last Edit: February 10, 2009, 12:45:06 PM by skitime »
