brake question....
  • 1219 Views
Offline Chief
  • 678
  • Whaddya lookin at??
brake question....
« on: July 06, 2005, 11:12:43 AM »
OK, I can now get a good brake....but only after pumping the pedal, and then it only stays for 1 stop, then almost back to the floor (All front brakes).
When I turn the truck off, and pump the pedal, it will stay high after a couple pumps, doiesn't bleed off, so I think this means the brake booster is ok.
What else to check??
Re: brake question....
« Reply #1 on: July 06, 2005, 12:25:48 PM »
Replace your rear brake shoes,
At least check the adjustment
Offline Chief
  • 678
« Reply #2 on: July 06, 2005, 12:37:34 PM »
Both already been done. I guess I should get all new hardware n springs......more$$$$$$$$  :-/
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #3 on: July 06, 2005, 01:00:32 PM »
This sounds like what's happening to us. Except, it's all rear brakes until you pump it, then you get the front too.
http://www.zukiworld.com/cgi/yabb/YaBB.pl?board=suzuki_talk;action=display;num=1116204255;start=0#0
What all modifications have you done? I'm sorry, I might have missed the posts.
We've replaced the booster and the M/C twice. I don't think it's those. We've also completely removed the ABS block in the front, that sat next to the M/C.
I'm thinking the next thing is to replace the front pads, but I'm also thinking we need to come up with a different M/C. As in my other posts, DOES ANYONE KNOW THE BORE of the SIDEKICK M/C? I've heard that some subaru M/C's, as well as some Toyota ones will work.
Anyway..
I hope we can both come up with fixes!
Heather Galvin
Offline Chief
  • 678
« Reply #4 on: July 06, 2005, 02:22:33 PM »
so THAT"S what it is!!!!!
Sh*T! I have ABS?!?! I'm pullin that stupoid plug tomorrow, see what happens! I bet that's why it's a fawked up, lift + bigger tires has the ABS freakin out.....
I'm REALLLLLLLLLLLLLY contemplating removing ALL the lines, and run a line to the fronts, and one to the backs, and a proportioning valve to the rear/w discs.... >:(
« Last Edit: July 06, 2005, 02:24:07 PM by Chief »
