WOOO HOOO !!!!! YOU GUYS ARE IN CRAWL MAG
  • 19 Replies
  • 4673 Views
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
Re: WOOO HOOO !!!!! YOU GUYS ARE IN CRAWL MAG
« Reply #15 on: November 30, 2007, 07:23:07 PM »
I actually finally broke the inner 26 spline Calmini anvil shaft. I was starting to think they were unbreakable. I had popped the front off the ground and to be perfectly honest I stayed on the gas too long when the front came down. I now have some custom 31 spline inner axles. I havent broke a cv since I built the new setup. The only cvs Ive broke are related to breaking inner tierods and the wheel overturns and breaks the cv. I have now switched the tie rods out to heims, so that should be cured now. I have also broke two of the shafts that go inbetween the inner and outer cv. They are welded and they break at the weld. It sounds a lot worse than it really is. As often and hard as I wheel this thing, Im pretty happy.
Mike
Offline bus_driver
  • 479
« Reply #16 on: December 02, 2007, 07:18:15 AM »
all things considered it really is amazing that you really only had minor challenges. and werent the tie rods stock items? i see guys with big buck items that break more and i know from what i see you are not a kitty kat with the throttle.
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
« Reply #17 on: December 07, 2007, 07:37:05 PM »
WOOO HOOO !!!!! I GOT MY CRAWL MAG! :P
I actually finally broke the inner 26 spline Calmini anvil shaft.  I now have some custom 31 spline inner axles.
Here is a comparison pic of the 26 spline and the new 31s. 8)
Offline BLK_ARMR
  • 175
  • Herculiner All The Way!!
« Reply #18 on: December 08, 2007, 10:07:26 AM »
HOLY $#!+
93 Tracker
Coated in **HERCULINER**
2pc Hard Top, Flares, 3" Body Lift, 31"x10.50" OTR Muds, 15"x8" Black "Wagon Wheels"
Offline 37kicker
  • 319
  • 97 tracker 9inch front and rear on 40" pitbulls
« Reply #19 on: December 08, 2007, 07:10:25 PM »
finally,  got mine too!!  stan
