Help, Samurai Owners w/ Calmini 3" Suspensions!
  • 1146 Views
Offline KonaSciDiver
  • 6
  • Before the lift... gotta take some new pics
« on: September 09, 2007, 07:43:03 PM »
I recently purchased the Calmini 3" suspension for my 88.5 Samurai, under the impression that it was a fully bolt-on kit. Then I noticed that towards the end of the install instructions, it said that "REAR BUMP STOP EXTENSIONS REQUIRE WELDING TO FRAME ABOVE RUBBER STOP ON AXLE.KIT."
Is this true? Their shackle-reverse kit appears to have the same bump-stop extensions on the website pictures, and that one specifically says "no welding required".
For those who have done this before, is it a difficult welding job? I've got a friend who's a welding student, and he might be able to help out if it turns out it does need welding (I would have no idea what I was doing)
Thanks for your help.
88.5 Samurai
Weber Carb, Ceramic Header
3" Calmini SPUA
"Dakine Custom" Rattlecan Camo
 "Rarely do great beauty and great virtue dwell together" -Petrarch
  • 6558
  • 64
Re: Help, Samurai Owners w/ Calmini 3" Suspensions!
« Reply #1 on: September 10, 2007, 07:35:53 AM »
Easy thing to do. It's a small piece of box tubing that is welded to the factory bump stop location on the frame. It is an "in position" weld with plenty of room.
« Reply #2 on: September 10, 2007, 07:46:32 AM »
One fella drilled holes and used self-tapping flange screws.  Worked fine and no welder.
Offline DaddyDave
  • 204
  • Indeed
« Reply #3 on: September 11, 2007, 11:28:53 PM »
Double check the directions, but I am sure the front ones are required (bolt-on) and that the rear ones are optional (based on tire size and clearance).
"The maximum effective range of an excuse is 0.0 meters."
