Hey Hotrod...
  • 8 Replies
  • 1761 Views
Offline museboy07
  • 641
Hey Hotrod...
« on: September 04, 2007, 07:43:05 PM »
A buddy of mine just bought a Tracker and the calmini 3+3 lift.  He wants to put 32x9.5s on it.  I recall you saying in a post that you have 32s with stock gears and no engine mods...how does that work for you on road, off road and highway??  Thanks man!!
Re: Hey Hotrod...
« Reply #1 on: September 04, 2007, 10:05:16 PM »
my 95 5spd 16v Kick wasn't that bad.
not much use for 5th gear on anything less than a down hill.
Drove it that way for the first year
on 32x10.5 SuperSwamper radials.
But for crawling, it's alittle hard on the Clutch.
For mud or trail riding, 4lo works good.
I'd go with the T-case gears next.
Not great but livable.
Offline museboy07
  • 641
Re: Hey Hotrod...
« Reply #2 on: September 05, 2007, 04:30:12 AM »
oh man his is an 8 valve..even less power
Offline locjaw
  • 2045
  • 22
Re: Hey Hotrod...
« Reply #3 on: September 05, 2007, 07:14:16 AM »
8v's have better low torque though
Offline museboy07
  • 641
Re: Hey Hotrod...
« Reply #4 on: September 05, 2007, 06:14:44 PM »
really?  didnt know that...i was thinkin bout goin for the combo lift with 32s too...i just cant afford gears...you think header, full 2in ehhausts, and like a k&n cold air intake would help turn them tires without gears?
Re: Hey Hotrod...
« Reply #5 on: September 07, 2007, 10:16:37 AM »
I'm not sure thats true. ISTR seeing a dyno chart comparing both and the 16V and 8V were the same through the lower part of the rev range. The difference was that further up the 8V levelled off and the 16V kept going.
My 33s measure about 32 now and with the stock 8V engine and gearing it was a real slug on the road. Noticably worse offroad on any kind of incline or descent too.
kingzoo
Re: Hey Hotrod...
« Reply #6 on: September 12, 2007, 07:35:04 AM »
   Proper front and rear gearing are the best solution.Power mods are allways welcome,but addressing the real issue is the best first step.
Offline museboy07
  • 641
Re: Hey Hotrod...
« Reply #7 on: September 12, 2007, 08:28:34 AM »
Yes but the problem is 5.83 gears for the rear are no where to be found...what the hell am i supposed to do about that??   ???
Offline WorkInProgress91
  • 31 gets it done
Re: Hey Hotrod...
« Reply #8 on: September 12, 2007, 09:31:50 PM »
kicker 3 with 4.62's.  ;D
91 sidekick
2'' B/L, 2'' coil spacers
31'' swampers
winch
custom bumper tank lift camouflage duct tape
