Missing 16v Found ALIVE!
  • 0 Replies
  • 850 Views
« on: April 06, 2008, 06:24:03 AM »
Found and happily alive and well. I probably at one time moved the timing belt 1 tooth after reading some posts on here, trying to gain more or better power. Forgot all about it, and consequently, this left my dist timing a tooth off too. DUH, should keep better records! As per Whitfields suggestion, removed dizzy lock down bolt, moved it further retarded, and it fired right up and ran perfectly. Just have to move the dist one tooth.
