... i was more surprised |removethispart|@ the difference in toe after my lift.
Amen to that!
I got myself the SPC cam bolts and did mine. Then, worried about chewing up my brand new Wrangler MT's, I took it to be professionally aligned.
I found out two things:
- 1. Tire Discounters (Ohio based) carries the SPC cam bolts!
- 2. Tire Discounters sells them cheaper than I got them off eBay!
Now, Not knowing that they could do the camber kit, I got it and did it myself using the carpenter square method found here:
http://bbs.zuwharrie.com/content/topic,45319.0.html... and found the I had the camber dialed in perfectly on the passenger side and off by +0.10° on the driver side. pretty good , eh?
That being said, the toe was
wacked. A vehicle with the tow as far out as mine was will eat tires fast.
So ask yourself, which do you want to buy; an alignment, or tires?
BTW, Tire Discounters gives a warranty on their alignments. So I'm gonna wheel around and take it back in periodically for a checkup!
